Question about Sewing Machines
Hi Can I sew plastic on 25 y.o. janome machine.
Hi Can I sew plastic (garbage bag thickness)on 25 y.o. janome machine. What needle size & thread length etc? This is an old machine sew I am not concerned about using it on normal fabrics again. This item is for a concert backdrop. The machine is at my daughter;s so I don't no the model.
Thanks
Christine
  • 632 Answers
Plastic is easy to work on. Any needle will work, I'd go with a sharp not ball point. The stitch length should be a bit longer so you won't have the perforated effect and cut through the plastic. A thin size thread will cut the plastic vs a thicker one. Always try a sample first so you can adjust the tension specially if you can adjust it from the bobbin. GL
Posted on Jul 05, 2010
What size needle is used on janome model 672
Janome makes sewing machine needles. However, many machine brands recommend using their own brand needles (ie Singer recommends only their needles and I have encountered issues using Singer needles with non-Singer machines). Sometimes, machine-brand needles are higher priced. More expensive does not guarantee better quality. However, unbelievably inexpensive off-brand needles may not be a good thing.
PRODUCT REVIEW JANOME SEWING MACHINE NEEDLES
Janome needles will most likely work fine on your machine, however, most modern sewing machines accept the standard 705/130 needle. Beware, though, that some brands of 705/130 needles have slight variations that may cause problems. If in doubt, consult your Janome dealer or an experienced Janome user. It may come down to experimentation on your own. Don't be surprised that a brand recommended may work better than others. Because a sewist is a staunch advocate of a particular brand, does not mean it will work best for your machine. It's just the nature of the beast because every machine and every needle has slight variations. Purchasing a single package of brand needles and trying them first would be a good idea. If the needle doesn't seem to work, you can try another brand until you find one you like. When experimenting with a different needle, start out sewing slowly (or hand rotating the wheel) in case there is a problem with the needle, you may avoid broken needles.
I've found several brands that work fine on my machines (not Janome machines) and seem to work for most sewists, ie Schmetz, Organ, Klasse, even Kenmore. It's probably best to avoid lesser known brands or bargain bin needles. Fabric stores, like JoAnn's carry Schmetz and if you use coupons, you can frequently buy them at a great price, sometimes 50%.
sewing patternreview com
How to Choose Sewing Needles Looking at Types Sizes Lifespan
Along with choosing the needle for your machine, you need to consider the thread and fabric you will be using. Choosing the correct needle is very important for your sewing success, ie use a ball point needle for knits, a leather needle for heavy fabrics/thread, a sharp/microtex for fine wovens, embroidery for applique & embroidery, top stitch for larger threads & heavier fabric, etc.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjixZv7tYfOAhVEYiYKHZRIAGEQFggkMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
And, above all, install a brand new needle frequently, ie whenever beginning a new project. A bent/dull/damaged needle will cause all kinds of frustration, including failing to pick up the bobbin thread, skipped stitches, or even hitting/damaging the presser foot, needle plate, or hook. A flying piece of needle is not a pleasant experience--and dangerous (wear eye protection)!
Jul 22, 2016 | Janome Sewing Machines
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be
checked for a timing problem
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 29, 2013 | Janome Harmony 2039 Mechanical Sewing...
Top thread is breaking on Janome 6600P
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 16, 2013 | Sewing Machines
While hemming jeans with my Janome 7061NX (using a 100/16 sharp), it skips stitches at the thick seams.
try a denim needle
Skipped stitches
Apr 18, 2012 | Sewing Machines
My thread keeps breaking when I sew over a seam, I have replaced the needle, tried a different cotton, & replaced the bobbin case & it still keeps breaking any suggestions?
Hi
You seem to have done everything as correctly as expected.
There are some minor things that could be disturbing yet.
Make sure that needle is exacly correct in her place and that the thread isthread from the correct side. One thing I knowworks wellwhen sewing thick parts is to hold the fabric in such a way that it is a bit streched under the needle and to let the machine go slowly over the thick bits.
Hope this will be of some help
Kolbrun
Mar 08, 2012 | Janome Memory Craft 9000 Computerized...
I am new to this machine & would like to know how to use metallic embroidery thread. Every time I try the thread breaks
check the tension
if the thread will not easily pull thru the needle eye you need one size larger needle
also keep under the needle plate clean of lint
& also the bobbin area
Nov 27, 2010 | Janome Memory Craft 9000 Computerized...
The top thread breaks as soon as i start the machine . i think i am threading it wrong
rethread the machine
thread tension to tight--set to 3 or 4
the thread is too thick for the needle-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
change needle & make sure it's inserted correctly
Nov 21, 2010 | Euro-Pro 416 Mechanical Sewing Machine
As others have written, my upper thread shreds and if I loosen the tension, I get skipped stitches. When not quilting, she runs just fine HELP Ann Marie
change the needle
some needles & thread are not compatable-try this
check to make sure there are no burrs on any of the thread guides
try a 3 or 4 top thread tension
Nov 03, 2010 | Janome 1600P-DB Mechanical Sewing Machine
My Janome mini compact will not sew through a double layer of flannel. I have tried changing the tension.
sometime the needle & thread are not compatable--try this & see if it work for you
Oct 14, 2010 | Janome Mini Compact
When starting to sew, cotton becomes knotted in fabric and machine stops. Have tried new cotton spool, new needle, checked for blockages, everything seems to be free-running. Advice please, thanks
it is possible that the needle & thread are not compatable
here's how to check
Oct 07, 2010 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
