Question about Whirlpool Duet GHW9150P Front Load Washer
My front loader washer is flasing 02 then f - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washer is no completing cycle. I see a F 02 code falshiing. How ca i fix it?
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects HERE"S HOW
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
I have a manual and repair photos HERE
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
F 02 reading on front loader washer.
I found several helpful sites from owners who had the same problem and they got the issues resolved, will try what they advised and if that don’t work I’ll call a service technician.
Oct 01, 2009 | Kenmore Elite 45986 Front Load Washer
My washer flases F and sud and will not drain
your using to much soap front loaders use 2 table spoons of soap and maker sure it's HE soap
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal De
