Question about DeLonghi Coffee Makers & Espresso Machines
I made the mistake of taking out the water tank when the machine was heating up. An error code came on saying ground to fine adjust mill and insert water spout and press ok. I have kept all supplies together and still have the original box but don't ever remember seeing the water spout and want to know if there is any way to bypass this so I can use my machine again or will I have to buy that part? Thank for any help you can give me.
  • 2,272 Answers
Water spout is external removable part in the coffee maker.But  You cannot by-pass the part as it will not support because the internal circuit will not get completed without the spout inserted .You will have to but the part.But take care you buy the exact part and not the compatible part.In DeLonghi Coffee makers the cheap compatible parts are not supporting and if supporting they don't last long.So buy original part from the DeLonghi service center.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 04, 2010
Ground too fine adjust mill comes on about every other cup.
With any coffee grinder (especially those that are used for espresso) the burrs can wear down after a while. It seems like you've used this machine quite a bit and for various different types of coffees. If your machine is still covered by the manufacturer I would suggest contacting them about the problem or call your local specialty coffee shop. They normally have or know of a guy that can fix this rather simple problem for cheap. Happy brewing!
Sep 03, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
I have a Delonghi EAM 3400 espresso machine. The problem I am having is that when I select an espresso very little comes out and it just drips instead of a full flow. It is also taking 4 minutes to brew...
It is likely that the coffee is ground too finely so if you turn the adjustment knob one click clockwise towards 7, while the coffee mill is working. Try clicking one click at the time until you are satisfied. Hope this works for you, Kolbrun
Nov 02, 2013 | DeLonghi EAM3400 Espresso Machine
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
On my Manifica which is about 5 years old I get the message that the ground is too fine and to adjust it when I am trying to froth the milk. I have cleaned it, adjusted it , taken all the beans out and it...
Hi
A grind that is too fine will result in your espresso being too bitter. Rinse between shots because the infuser clogs easily with black espresso muck. Not rinsing will cause the machine to shut down with a message that the "grind is too fine".
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. Try turning the grinding regulator 1 click clockwise and see if that works.If not try inserting the water spout press the ok button and then run water a few seconds.
If you remove the water tank too early while it is making coffee it will display that message as well.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 03, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Coffee Makers & Espresso Machines Logo
156 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
