Very little water getting int the machine when
Very little water getting in the machine when washing, but pipe is not blocked. The clothes come out half washed
    Champion:
  • 274 Answers
Thats how these machines work they dont use much water but always use a H.E soap and bleach the machine is ok
Posted on Jul 05, 2010
Schaublorenz wa 5005
Try pulling out the soap / softener drawer completely from the Machine and thorough cleaning all the parts. The little siphon plastic pipes get blocked and cause this on my Hotpoint.
Aug 01, 2014 | Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Washer does not have enough water, and when it spins it doesnt spin enough to get all the water out of the clothes.
a few things to try... the water fill pipe that feeds the machine, check the tap at the end to make sure its on full, if it is then turn water off and unscrew pipe from rear of machine and see if connection on machine is blocked or clogged. then usually located at front of machine at the bottom, unscrew the filter to see if its blocked with small change ( usual suspect ) and try.
Dec 16, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My maytag neptune washing machine is not spinning out the water from my clothes once its done washing. My clothes are still soaked even after its done and theres a little bit of water left in the...
you have a partially blocked drain from the tub down thru the pump to the drain pipe,remove the lower front cover and remove the drain cleanout and check for blockages in these hoses
May 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
My kenmore washer will not drain ater wash cycle,but when i vaccum the water from the wash tub it will spin and drain the clothes?what do i need to check ?
the pump sounds like it blocked or the drain hose is in to tight and causing an anti-siphon
first pull the drain out and then put it back in put a little water in the washer and spin it out lift the hose in the pipe see if you see water coming out if not you have a blocked pump
Apr 17, 2009 | Kenmore 22622 Top Load Washer
Black marks on clothes
I had a similar problem. We has placed the waste water hose into an old tub next the machine. The plug hole int he sink has become blocked with lint. When the washing maching was pumping water into the tub, the tub would fill with water, which would rise a level higher than the washing machine waste hose. What this appeared to do was cause the machine not to be able to properly pump out water, leaving this horrible back stuff in the wash which would end up all over the wash. Ensuring the plub hole in the tub was clear solved the problem immediately!
Mar 01, 2009 | Fisher Paykel EcoSmart GWL15
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
SPIN
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
