Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
I have removed a clog from the hose and cleaned the air filter. But I have no suction. If i remove the filter the is plenty of suction.
    Master:
  • 501 Answers
Get a new filter
Posted on Jul 04, 2010
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I cleaned all the filters and it doesn't have any suction
Check the hoses for a clog. Sometimes the hoses themselves will get clogged and cut off suction -- other times it happens between the beater brush and the hose (within the cleaning head itself). If this is the case, when you turn on the vacuum it will make a higher pitch sound than normal, and sound like it is working really hard, even thought there is no suction. If you can't reach the clog, but you have found it in the hose, you can usually use a coat hanger to either loosen it up or remove it completely from the hose. If this does not work, you can try loosening the clog with another vacuum. Just use the second vacuum to reverse the normal air-flow through the hose ... sometimes this will loosen it up and get your equipment to work.
May 26, 2011 | Eureka 3276AVZ Bagless Upright Vacuum
I am not getting any suction?
if youi are not getting any suction - remove and clean the filter ( tap it/brush it or use a air compressor to blow clean ). also check the hose near the bottom of the vacume where it bends - dirt loves to build up there and clog the hose.
c...
Dec 31, 2010 | Dyson DC07 Allergy Blue/Turquoise Bagless...
There is a suction problem - the suction power is very low. The filter has been washed, dried and replaced but the problem is still there What is the problem? Thanks.
Something between the bag and the suction opening is clogging the vacuum. Start at the bag. Remove the bag and check for a clog. Remove the hose from the back and check for clog. Release the handle and turn the machine over to expose the sweeper bush. Check for clog. If you haven't found the clog at this point, remove the 4 screws on the brush cover. Then remove the brush and check the hose going into the machine. If the filters are clean the machine should have plenty of suction.
Nov 27, 2010 | Hoover Vacuums
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have Bissell Powerforce Bagless Upright Vacuum. it doesn't suction well. I checked the belt. It is ok. may be clog in the hose.I don't no how to clean. can you help me please?
- Check the dirt cup to make sure it is empty.
- Your vacuum has 3 filters. Dirty filters will restrict air flow. The filters may be hand washed in cold water with mild detergent. Allow them to completely dry prior to reinstalling them. The white HEPA media post-motor filter is not washable.
- Lift the upholstery hose from the bottom holder. Check for suction at the end of the hose.
If there IS good suction at the end of the hose, please unplug your machine from the outlet and try the following:
- Ensure the hose is firmly pressed into the lower hose outlet on the back of the vacuum.
- Check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum. Check the belt and clean the roller of dirt and debris.
- Check the lower hose for clogs by removing the screw which attaches it and lifting the hose up to clean it out. Also, remove the larger hose by twisting it off and using a broomstick handle, push any dirt and debris through the hose.
Aug 05, 2010 | Bissell Vacuums
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
165 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
