Question about Frigidaire ATF6000ES Front Load Washer
Front loader moves to much. I already balance in place it but it still moves to much.
    Champion:
  • 274 Answers
Ajust the legs on the bottom of the machine see if this works if not write back
Posted on Jul 05, 2010
My machine is spinning really loudly and moving from its original spot. Is it out of balance. How do I fix it. It's used daily.
you forgot to mention if it is top loader or front loader
if top loader check the 4 suspension rods that hold the tub up are intact
if one is longer than the others then it will always be out of balance
call a technician for a proper diagnosis
Jul 13, 2016 | Washing Machines
Why does my samsung washer thump when it is trying to spin
Load is not balanced. Move clothes around in bowel to distribute the weight. If its front loader, take some out and see how it does. They typically balance themselves, but if you load too much in them you may have to help it a little...front loader may have leg out of level also.
Jun 02, 2014 | Samsung Washing Machines
We got a figidaire washer for a gift (the front loader model). We are having issues with the balancing of the washer... we know the feet turn on the bottom but after adjusting them it still was out of...
hello on some machines there are load senors. you already may have done this get spirit level set the feet of the washer again. also with power off check inside the machine make sure the 2 large bricks are not loose the 1 at the bottom is usually bolted on the 1 at the top is attach by 2 large springs hope it helps
regards
shaun
Apr 23, 2011 | Frigidaire ATF6000ES Front Load Washer
How do i balance my bosch front loader washer........it moves all over the place
Idealy ,you need to make sure that the machine dos not jump all over the place , this involes adjusting the front feet ..you could use a spirit level doing it well to adjust the levels across and front to back.....
Jan 07, 2011 | Bosch Washing Machines
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Washer Tub Balance
A "professional" does not really balance the tub of a front-loader, they balance the washer. You can do this as well... there are 4 feet, just get a level and move feet up or down to get the machine leveled. Check the horizontal level and then the vertical level. Not too hard unless the feet, legs, are rusted shut in which case you can attempt to shim it up. The unit should not rock back and forth at all in any direction when it it leveled. Front loaders will vibrate, sometimes a lot, until they reach the full RPM of the spin, this is normal.
Jul 21, 2009 | Washing Machines
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
