Question about Home
I need a replacement bracket for my Creda heated towel rail
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 18 Answers
  • Clayton Jr
    Clayton Jr Jul 17, 2010
    Curios if this was helpful?
I need two brackets for my 60watt creda heated towel rack
I think that is very unlikely as they seem part of the tube in manufacture. You could contact them direct. The only other alternative would be to use plumbing pipe clips, but they are a bit industrial.
Here a few.
http://www.bing.com/images/search?q=plumbing+pipe+clips&FORM=HDRSC2
Creda Heating Towel Rails
Jul 05, 2016 | Home
How to fix creda cooker all of the hobs when put on are unable to control heat
[PDF]Product Directory Summer 2013 - Creda Heating
www.credaheating.co.uk/assets/kb/brochure/.../Creda_Nobo_Brochure.p...
Creda Heating range, installation and operating instructions, brochure ... installations. We are able to offer an expert application design service for all our.
The Different Functions And Uses Of The Oven - Creda ...
www.manualslib.com > ... > Instructions for installation and use manual
Creda J052E Instructions For Installation And Use Manual: The Different Functions And Uses Of The Oven ... For all other types of. cooking, never ... cooking functions are set up by operating the two knobs: ... The oven light turns on and the top and bottomheating ... permit reaching the maximum (250°C) temperature inside.
[PDF]Instructions for Installation and Use - you
Jan 24, 2016 | Creda Kitchen Ranges
Wireing a heated towel rail to a permanent switch
A simple on or off switch, connect power to 1 screw and rail to the other screw. A dimmer or reostat is the same. Select amp rating of the switch higher than the amp draw of the rail.
Dec 07, 2013 | Electrical Supplies
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
The towel bar keeps coming off the brackets. How do I get this corrected?
Hi. Are the brackets (mounting posts) the correct distance apart? For a 24" rail, they should be 26.22" apart (outside to outside). If they are not then they probably need to be moved so that they are.
If they are correctly spaced, are the "notches" in the mounting posts facing downwards? If not, make this so.
If the notches are facing downwards, are the screws tight enough? If, not, tighten screws.
Hope this helps. Regards, Myles
Dec 31, 2010 | Moen 24 In. Towel Bar...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
I need to replace de fuel presurre sensor in a pontiac montana ,do i have to just replace the sensor ,o the sensor came with the fuel pump?thank you
Replacing the fuel pressure regulator, involves just replacing the regulator at the end of the fuel rail in the engine compartment, but fuel pressure sensor - does this mini-van have a fuel pressure sensor?
replacing the fuel pressure regulator: (1) locate it at the end of the fuel rail in the engine compartment,
(2) relieve fuel system pressure (3) disconnect fuel pressure regulator vacuum line. (4) remove fuel pressure regulator retaining screw (retain for re-use (5) using a shop towel to catch spilled fuel, lift & twist Fuel pressure regulator to remove it from the fuel rail. (6) remove/discard retainer and spacer bracket from the fuel rail. (7) remove fuel pressure regulator from the engine fuel return pipe. (8) remove/discard Fuel Pressure Regulator inlet O-ring (9) Check Fuel Pressure Regulator filter screen for contamination - if contaminated, replace Fuel Pressure Regulator. (10) Lubricate new Fuel Pressure Regulator inlet O-ring with clean engine oil & install onto the Fuel Pressure Regulator inlet. (11) Install the fuel return pipe onto the Fuel Pressure regulator (12) Install new retainer & spacer bracket into the slot on the fuel rail.
(13) Install Fuel Pressure Regulator onto Fuel Rail & tighten Engine Fuel Return Pipe nut to 13 ft-lbs (17 Nm). (14) connect Fuel Pressure Regulator vacuum line, (15) Install Fuel Pressure Regulator attachng screw & tighten to 76 in-lbs (8.5 Nm). (16) Inspect & verify that retainer & spacer bracket is engaged in the slots on the fuel rail. Grasp & pull on the Fuel Pressure Regulator.
to ensure that the Fuel Pressure Regulator is properly seated. (17) inspect for fuel leaks with this
procedure: On 2sec,(holy rollers), off 10sec will be left on, inspect for leaks while running.
Dec 11, 2010 | 2000 Pontiac Montana
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Nov 16, 2008 | Creda C362E Electric Kitchen Range
Home Logo
337 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
