Question about Samsung LN32A330 32 in. LCD TV
The middle of the screen is blank
The top and bottom has a picture. is it worth fixing
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
This is probably the T-con board and probably not worth fixing. It could be the signal board, missing back lighting, etc but again, probably not worth fixing.
Best Regards,
Beach TV Repair
Posted on Jul 04, 2010
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
How do I reset size of picture as picture is in middle of screen
check for the zoom function in the remote control...change the ratio
Aug 26, 2012 | Hannspree 28" Widescreen Flat-Panel LCD HD...
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
Sony KP53V15 picture is half on top and half on bottom - what could fix this?
Do you mean it's blank in the middle or blank top and bottom.
Either Vertical o/p problem or cc (closed caption) is on
If cc - check on screen display to turn off cc.
if Vertical o/p read below-
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 22, 2009 | Sony Televison & Video
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
Television fault
it is not worth fixing get a new tv
Oct 31, 2007 | JVC AV-27020 TV
Samsung LN32A330 32 in. LCD TV Logo
153 people viewed this question
Henry  Thomas
Henry Thomas
