Question about Garden
Ryobi SS30 Trimmer. Need to rewind pull cord. I already have the housing off. Need to know the next step in removing clutch assembly.
    Master:
  • 502 Answers
Cut handle off,let spring unwind.remove piece that stops pulley from coming off,then take pulley off,should leave spring intact.dont touch the spring,hell of a job to refit..bolt holding clutch assembly is usually left hand thread.usually two springs holding the two small brake shoes.reasonably easy to go from there
Posted on Jul 04, 2010
Replace pull cord for ryobi ss30 weed trimmer
There are 3 Scres that hold it in place
Apr 07, 2013 | Ryobi Garden
Craftman weedacker
  • Hole in the end of the clutch housing where the cable slides in has a # 20 torx screw in there.
  • Pull the spark plug, stuff some rewind starter rope in the plug hole, use a water pump pliers and turn off the clutch plate(s). NOTE: curved shaft trimmer will be a standard right-hand thread, straight shaft will be a left-hand thread.
Oct 04, 2008 | Craftsman 25cc Gas Line Trimmer
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How to reload pull cord spring assembly?
not it not easy but can be done
found this on a web site should tell you what you need to know
john
I removed the screws from the bottom of the unit to separate mechanism that held the blades from the engine. This revealed a clutch on the end of the drive shaft. I removed the springs so I could remove the two halves of the centrifical clutch. I did this so I could then remove the mount these two halves were around. This mount had an arrow and the word 'off' on it. I placed a block of wood against this mount and hit the wood (protecting the mount) as to spin off the mount in the direction of the arrow. A few sharp licks with the hammer and the mount started to come off. I removed it by hand then. Next I removed screws and spark plug so I could get the green housing off where the cord was mounted. Inside this housing is a white spool the cord was on. Becareful with the next step. To replace the cord I removed the spool the cord is wound on but be careful, under the spool is a metal housing under which is the spring that rewinds the cord when you pull start the unit. The end of the white spool that is out of your sight meshes with the end rewind spring. If you pull too far up on the spring or the metal housing that keeps the spring in place you will have spring everywhere and possibly toward your face becareful. So Loosen the two screws and turn the tabs out of the way that hold down the white cord spool. Slowly work the white cord spool off. Replace the cord on the spool making sure you wind it in the proper direction. Then replace the spool and mesh it with the spring. Turn the spool to wind the spring and retention the pull cord rewinding spring. re assemble unit. Good luck! This is not a step by step but I believe it will get you what you need.
Feb 26, 2011 | Garden
I have a Ryobi 700R trimmer - I need to know how to replace the pull cord - Tom
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case:
1. Disconnect the shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts).
3. Pull the cord until the stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
Use proper line and reverse for new line. Good luck!
Aug 31, 2010 | Ryobi Garden
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
How do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
May 14, 2009 | Garden
How to pretension starter cord on ryobi whipper snipper
Remove the housing and pull the cord partly out. Then rewind the rest. Check to see if it retracts properly. Good Luck!
Dec 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi ss30 (ry30544) pull string keeps jamming
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
