Question about Panasonic PT-53WX42 53" Rear Projection Television
Can someone help Panasonic tv will not turn on power light 3 blinks and a pause (pt-53wx42-53
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 3 blinks issue means failed convergence (STK) ICs which needs to be replaced. To do this yourself you should require some basic knowledge about soldering-re-soldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Turn tv on,tv shut off then power light blinks 3 times,pause and continue to blink 3 times
Check the site www.TvRepairKits.com - your convergence may have shorted out causing the tv to power off.
Apr 24, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Does anyone know what a "d" board is for a 53 Rear projection Panasonic Tv? If so, where can I get one and is it hard to repair on my own?
The D board is the deflection power board the power cord goes to ---not available from Panasonic.
For me to help I need to know what set does or does not do.
This model has a error code, if it tries to turn on and shuts off the power light blinks a sequence---like 3 blinks, pause or 5 blinks pause.
The more you tell me the better I can help.
SD TECH
Sep 29, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My Panasonic PT-53TW53 53 in. was working fine last night when I turned it off. Today it doesn't turn-on at all. it's plugged into a surge protector and no thunder storms today... what could be the...
I am someone who knows these sets very well.
One of two things should be seen:
If when you turn set on it does not come on----DOES THE POWER LIGHT BLINK IN A SEQUENCE?
Most common in this model are 3 blinks, pause 3 blinks forever.
Next is 5 blinks 5 blinks etc forever.
Does your power light blink/
Also, I know this model but what year/month was it made? Date will be on a label on the back.
I helped someone else today here with a similar problem.
In his case the set came on and after a few minutes he saw a faint top to bottom band of noise to the right of center in the screen, the rest was black.
The more you tell me, the better I can direct you.
Regards, SD TECH
Aug 14, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Tv will not turn on. red light on front of tv next to on/off button blinks
COUNT THE BLINKS.
3 BLINKS AND A PAUSE AND 3 BLINKS IS MOST COMMON.
5 BLINKS AND A PAUSE AND 5 BLINKS IS ALSO COMMON.
let me know the error code (blinks) and I will tell you what it means.
SD TECH
Jun 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Tv will not turn on and there is a red light that keeps blinking in the front of the tv. buy the power button. It was working great when we went to bed and the next morning the tv would not come on.
COUNT THE BLINKS---the SET will usually have a blink or error code----3 blinks and a pause is most common on this PT-47WX49 model.
Confirm model number to me and how many blinks and I will try to tell you what is wrong.
I hope you find 3 blinks, pause 3 blinks as that is the most easy for repair--it is short protection and usually means a problem in the set's CONVERGENCE circuit.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Nov 08, 2009 | Panasonic PT-47WX49 47" Rear Projection...
TV no turn on power light blinks.
An answer would be nice on this issue please.
Sep 13, 2008 | Panasonic PT-53TW54 53" Rear Projection...
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
