Question about Epson Stylus CX6400 All-In-One InkJet Printer
I replaced 4 cartridges of ink a week ago but red and yellow color can not be printed out , so I just cleaned the head of printer several time , but it still does not work . Please kindly tell me the solusion of this problems. My printe is Epson stylus CX6400. Thaks.
    President:
  • 3,278 Answers
Hello.
Give this a try:
(1) Open the printer
(2) Remove the color ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now.
If that does not work then the print head(s) may need to be replaced.
Hope this helps.
Posted on Jul 04, 2010
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
Epson stylus c88 red ink prints yellow
print a check of the nozzles, and check what colour (magenta) is not working. If the cleaning part does not help, perhaps you should put a new cartridge in, or clean again.
Feb 17, 2015 | Epson Stylus Office Equipment & Supplies
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Oct 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
"WRONG CARTRIDGE" continues to flash on the screen.
I have experienced the "Wrong Cartridge" error about 4 times in four years. I have never bought a replacement print head. I do occasional printing each week. Typically the problem occurs after a color cartridge goes empty and the ink dried to the print head. The solution for me has been to remove the cartridges, remove the print head, place the print head in hot water in the kitchen sink (softens water based ink that has hardened)and then use a Q-Tip or tissue paper to clean the print head until it is nice and shiny. Reinstall the print head, insert ink cartridges that are not empty, let the printer cycle through a self-test, use the set button to accept vertical and horizontal print patterns and you'll be good to go!
If that doesn't fix it, you'll need to replace the printhead ($49-69 depending on where you buy it.
Oct 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
PIXMA ip3000 printer is printing yellow instead of red
Clean the ink cartridge contacts with a moist tissue or glass/LCD cleaner clothe. Do the same on the printer cartridge holders. Do this gently and carefully avoiding further damages to your printer and it's cartridges.
Declog print heads using denatured alcohol for an hour or two or head cleaning agents available at any ink refilling stations. You can use a suction device included in the refill kit.
Try using another cartridge of the same type by borrowing from a friend, relative or member of the family and see if the problem still occurs.
Try removing the printer driver, restart computer then reinstall driver so that the default settings will be restored. If it still exist, you can google for iptool software and try resetting it's EPROM.
If the problem still exists, you need to go to the nearest service center.
Dec 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
