Question about Sharp AL 1215 Black and White Copier
Sharp AL-1540cs reset for drum
Hey, is there some sort of reset code after replacing a drum or will it automatically reset once installed? thank you
  • mdanno May 09, 2009
    I have
    Sharp AL-1530cs. I need to reset for drum
  • Sharp Master
  • 2,794 Answers
Its supposed to reset itself without a service code. If it isn't let me know.
Posted on Jun 12, 2008
Frigidaire affinity dryer code ad
Hey Cindy, thanks for your submission!
I see that your Frigidaire dryer is displaying an error code of "ad". The "ad" error code will display with the "Auto Dry" cycle has been selected. If you did not select the auto dry cycle I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord for at least ten minutes. Once power has been restored to the dryer and if the error code is still persistent you may need to have a replacement control panel or wiring harness installed. I would recommend having electrical parts replaced by a professional technician this will prevent any personal injury. Best of luck! -Matt
Mar 08, 2016 | Frigidaire Dryers
How to reset xerox m118 drum counter
Hi Laurynas Straksas,
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
How to reset drum counter on bizhub 200
Utility counter, details stop00 stop01. Counters. Has the drum been replaced? if not you reset the counter the machine will assume that a new drum is install and select the proper voltages for a new drum since the drum is not new? it might code and get poor image quality issues. Replace the developer with the drum. Machine uses the counters to determine setting in the machine, developer also has a counter. Does the front panel say replace PC drum? If so replace developer and drum and cleaning blade at the same time. You clear counters before pulling out the image unit. and you don't exit all the way out of service mode after clearing the counters you hit exit once the turn off main power, Rear left side. Once new drum and developer installed. RUN F8. Do not allow copies Prints or fax until F8 is run. Or start all over again.
Jan 03, 2014 | Minolta bizhub 200 All-In-One Printer
Drum reset counter
When the drum is replaced the counter on the DP-C264 automatically resets. If it does not reset then the flag on the back of the drum has been damaged in shipment or during the install of the drum.
Oct 11, 2013 | Panasonic DP-C264 Color Copier
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
How can i change drum
Once you have the new drum unit, and are ready to install, just open the front door. Slide out the toner cartridge/drum unit combination assembly. Press the release tabs on either side of the toner cartridge and lift it up and out of the drum unit. Set it aside. Unpack the new drum unit and go over the installation instructions if you have them. Basically you are just removing all of the packing materials for the drum unit. Once that is done you need to install the old toner cartridge into the new drum unit. It just slides in and locks down. Then install the whole assembly back into the printer.
Leave the front door open, and press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This should complete the installation process. Just run a test copy to verify all is well.
Good Luck and Thank You for using Fixya.
Sep 26, 2010 | Brother MFC-8860DN Printer
Makes a grinding noise near the drum. Copier works, but makes a "gear-grinding" noise near the drum area. Can't tell what's doing it.
Un load the drum unit, check the drum/s gear, is it wear off, if so change it along with the drum's drive gear at machine base, check also the gears of developing unit
Jun 29, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL 1215 Black and White Copier Logo
237 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
