Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Are the bolts on a John Deere F715 blade right or left hand threads
  • 8,197 Answers
The bolts that hold the blad on are left hand thread.
Good luck and please rate 4 thumbs up for the free answer.
Posted on Jul 04, 2010
Are the Cutting blades bolts for a John Deere LT 160 right handed thread or left handed thread?
It is typical to use right handed thread so you would turn them clockwise to install, and counterclockwise to remove. The blade rotates towards the cutting edge which is typically counterclockwise, so to remove the bolt, you unscrew it, with the handle of your wrench pulling towards the back of the blade.. These bolts can be really tight. Pull the spark plug lead or remove the ignition key so you don't get an accidental start. Wear gloves, there are sharp bits.
Mar 17, 2015 | Cars & Trucks
Does the blades have left hand threads or right hand threads when relacing the blades
The blade bolts have a normal right-handed thread orientation. But remember, when you are installing a blade bolt, the bolt is facing UP from the ground, not DOWN to the ground; hence the confusion.
Jul 19, 2011 | Craftsman Garden
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
I wish to know which direction do i turn the bolt to take the cutting blade of a john deere ride on/ clockwise or anticlockwise?
As you are looking at the blade and bolt from under the mower, if the blade is rotating counterclockwise, then the blade bolt is standard threaded and will turn counterclockwise to loosen. If the blade is turning clockwise, then the bolt is left hand threaded and will turn clockwise to loosen. John Deere produces mower decks with both setups.
Dec 30, 2010 | John Deere Garden
Can't get blades off bolts very tight unsure which way to losen
Bolts should be a standard right hand thread ( rightey-tightey...leftee-loosey ) clean all rust and grass residue off the bolt heads and spray with penetrating oil or WD-40 and allow to sit overnight...sounds like the bolts may be rusted in place...I use a socket and an 18 inch 1/2 inch drive breaker bar to to remove the bolts...if they will not turn loose, try having someone hold the blade or jam them in place with a piece of 2x4... apply pressure on the breaker bar...and give the handle a good whack with a hammer.... that should pop them loose, or if you have access to an air impact wrench that will work also...here's a tip for ya....after you get the bolts out, clean the threads with a wire brush and apply either anti-sieze compound or waterproof grease to the threads of the bolts before re-installing they won't stick again....( another little maintenance procedure they don't tell you about)...good luck !!! ;-D
Jul 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ihave an old john deere lawn mower 21 inch #GX1458. Is the blade screw left or right hand thread
Always unscrew the bolt in the same direction of blade travel.If the blade travels clockwise,loosen bolt by going clockwise.
Mar 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Are blade mounting bolts left or right hand threaded ?
Right hand threads. I just replaced mine. The bolt will turn off in the same direction the blade turns when it is running.
Aug 08, 2009 | Mtd Arnold Corp No. Mtr - 42 - Ec 42" Mwr...
Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
161 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
