Question about Carrier 38CKC036 Air Conditioner
Our air conditioner is blowing air but not cool air, we are inspecting the outdoor unit the fan is not running.
  • 456 Answers
Turn the power off and then back on, canyou here the copressor come on?
Posted on Jul 04, 2010
    Scholar:
  • 80 Answers
Check wires to capacitor for burns, check capacitor is sweld up, check that fan blade will move freely and not siezed. Replace Capacitor if so or replace fan motor. I do both when the fan is siezed! Make sure to use same cap rating and same amps/hp on fan motor.
Posted on Aug 27, 2010
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Intertherm a/c hardly blows on low fan setting
are you saying the outdoor unit does run, then shuts off?
if not, there may be fuses in the disconnect
if so, it may be going out on low pressure, possibly high pressure....clean all coils, filter, blower wheel, inspect coil if possible
Jul 26, 2012 | Dometic Rooftop RV Air Conditioner
When i tunn on my AC unit at the thermostat it blows the 3 amp fuse in the air handler when it call for cool when i switch the t stat to off and just turn fan on the fuse does not blow and blower runs
sounds like the compressor is or a electrical component directly linked with the cooling operation/ outdoor unit running.
Possible short to earth....
cheers
Jul 05, 2010 | Ruud UBHC Air Conditioner
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
Fuse on control module blows when calling for cooling
Yes.
Disconnect the the red and the yellow wires at the outdoor unit. Then replace the fuse and turn on the power.......see if the fuse blew. If the fuse blew, your problem is most likely a short in the low voltage wiring. Check for crimped or damage wire or wire insulation and repair as necessary. If the fuse is okay, then the problem is within your outdoor unit.......again inspect all wiring for any damaged insulation or crimped wiring.
Check these items and let us know.....we can guide you further after you perform these checks. :-)
May 26, 2010 | Goodman CLQ36AR49 Air Conditioner
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Carrier 38CKC036 Air Conditioner Logo
411 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
