Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
We have a Kohler pullout faucet. We have had it for about 9 mos. Lately when we first turn the water on the water is fizzy or foamie for the first 2 seconds then clears. What is causing this?
Sorry, I don't have a solution, but I do have the same problem, a month after installation. Water has a very acrid odor too
Posted on Jul 14, 2010
  • ruyoung Sep 24, 2010
    Ditto - Installed new faucet in March and 3 weeks ago (now Sept.) our water turned fizzy and acrid.
    The good news: Kohler has documented this problem and says the plastic feed hose to the pull out faucet has a chemical reaction to some kinds of water. (I am the phone now (800) 456-4537
    Apparently they have no solution yet, but they offered to replace it with another comparable pull out faucet. While disappointed, I must say that Kohler has been very good on the customer service end of things, here and with another issue I had with my bathroom faucets.
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
Moen troubleshooting
Get in touch with the company that made it. Allot of times the company has a lifetime warranty on their faucet.
Jul 18, 2014 | Kohler Model 10433: Fort® Single-control...
Kohler - Coralais Pull-Out Spray Kitchen Faucet
te leak most likely is the cartridge you need to take the handle off and there will be a lock nut under where the handle was, turn the water supply off and remove the nut the cartridge will pull staight out, cartridges can't be repaired they need to be replaced. Watch out because some cartridges cost more than what the tap is worth
Jul 12, 2010 | Kohler K-15160-7 Coralais single-control...
K-15160 Kohler faucet switch to change single stream of water to spray is stuck. It will not return to a single large spray. How do I fix this?
they get gunked up with grease and junk, and or mineral deposits from well water---unscrew the aerator housing(underside of rounded pullout part) inspect and clean all part making sure there are no cracks in plastic junk used today...also noting correct placement of parts
Mar 13, 2010 | Kohler Model 15160L: Coralais®...
I have a Kohler Forte Single handle faucet, and I'm seeing leaking down below the sink in the cabinet. I tried reconnecting the Kohler piece to where the water comes out, but now it's even worse. It looks...
Turn off your water supply to the sink the disconnect the supply lines to the faucet. Reconnect supply lines making sure to use plumbers pipe joint compound of teflon tape. I've found teflon tape to be better. When installing the supply lines make sure that the threads aren't crossed and the retaining nut is snug.
Mar 12, 2010 | Kohler Model 10433: Fort® Single-control...
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
454 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
