Question about Whirlpool GW397LXUS Stainless Steel Gas Range
The gw397lxus oven is locked n sabbath mode and I can't unlock it
That is it. The oven turn on the sabbath mode itself. Now, I can't turn off...
3 Suggested Answers
  • 121 Answers
SOURCE: oven door locks then unlocks in self cleaning mode
sounds like you have a bad door lock mechanism/ can try one thing . open door, hold door light switch in if you have one on your model not all models do.then turn on self clean let it run for about 5 minutes and see if it resets itself if it does great its fixed, if not your lock latch may be bad. part is roughly 45-85 dollars and labor 75-125 depending were you live.hope this helps.
Posted on Sep 16, 2009
SOURCE: I have a Whirlpool Accubake model GW397LXUB.
Press and hold the "Control Lock," "Control Lockout" or "Lockout" button on the control panel of the oven until "LOC" or "LOCKOUT" disappears from the LCD screen or press and hold the button with the symbol of a padlock. Touch any of the buttons on the control panel except the "Clock Set," "Oven Light" or "Timer" buttons to ensure the lock was disabled. The "Clock Set," "Oven Light" and "Timer" buttons are still operational when the lock is enabled. Enable the oven lock by pressing and holding the "Control Lock," "Control Lockout" or "Lockout" button until "LOC" or "LOCKOUT" appears on the LCD screen
Posted on Dec 11, 2010
I have an LG LRE6383ST range. When in Sabbath Mode, how do you know when the grill is on and off?
When in Sabbath mode the only thing that functions is the oven and it will remain on until Sabbath mode is cancelled. You can still change the temp while in Sabbath mode. If the light is on in the oven when Sabbath Mode is activated it will remain on. To turn it off you have to make sure it is off before turning on Sabbath mode.
Apr 04, 2017 | LG Kitchen Ranges
How do l clear sabbath from display?
Users manual go to Whirlpool.com highlight service and support click on manuals and literature enter your model number users manual pops up it will tell you how to cancel sabbath mode
Feb 17, 2015 | Whirlpool GW397LXUS 30-Inch Slide-In Gas...
Stuck in sabbath mode
Hold down clock button for 3 seconds
Dec 31, 2012 | Whirlpool GW397LXUS Stainless Steel Gas...
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
WENT TO SET CLOCK, SOMEHOW DIS-TURBED THE CONTROL BOARD, IT IS LOCKED, READS 5A6, CAN I UNLOCK IT?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab" or "5A6.
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Mar 13, 2011 | Ovens
How set sabbath mode??
to turn on or off the sabbath mode on your oven press and hold the sabbath mode button for 5 seconds that turn it on and then repeat to turn it off
Apr 04, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid superba oven
Hit the options button and check that the "Sabbath mode" setting is off. I note that October 20th was a Tuesday but the internal clock year could be incorrect.
Oct 20, 2008 | KitchenAid Ovens
Need to unlock Sabbath mode from Maytag MGR4452BDW
I have a Crosley gas oven and I had the same problem. According to my manuel it will shut off automatically after 72 hours OR Press the CLOCK pad for 5 seconds - no beep will sound. The Sab will flash and then the time will be displayed.
I hope this helps.
Oct 05, 2008 | Maytag Kitchen Ranges
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven and clock inop
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Apr 05, 2006 | Amana AER5515QA Electric Kitchen Range
Whirlpool GW397LXUS Stainless Steel Gas Range Logo
73 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
