Question about LG LRE30451 Electric Kitchen Range
What does F7 error mean? It is self cleaning, blue interior with bottom warming tray
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F7 on your LG means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
F7 error code after oven shuts self down during baking
Error F7 on your range means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Jun 18, 2011 | Ovens
What does F7 code mean?
hello,
The F7 is an error code that means indication of a water temperature sensor error over flow from it oven which level is below 6degree
what you have to do to fix up this problem is to unscrew (open)the oven then clean up all form of water from the wire and also on the screen /panel then couple it back with care and allow it to relax it self for some time.
please DO NOT APPLY WATER when doing this and also make sure that all form of power supply is put OFF from the switch
hope this help.?
thank you and thanks for using fixya.
Sep 03, 2010 | GE JTP86 Electric Double Oven
Stove is beeping and displaying f7
Hi
Thanks for using FixYa. Error F7 on your GE means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 29, 2010 | GE Profile 30" Self-Cleaning Freestanding...
About 1 hour into the self cleaning process the F7 error light came on and I meed to know how to get rid of it?
on maytag's the F7 means a function key is stuck or shorted. google your oven model's codes.
Jun 22, 2010 | Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Cleaned stove, replaced bottom element, stove reading F3, F7 and F9. Oven will not work. But will work on Clean Cycle.
Initially, it sounds like a problem with the lock mechanism. Without the brand or model number, it's impossible to know what the fault codes mean. You may find them listed on a tech sheet in a plastic pocket behind the console.
F3 is usually a temperature sensor. F7 may be a keypad problem and F9 (on some machines) means there's something wrong with the door lock.
Sometimes during a self clean cycle, a high temp thermostat/ fuse fails, preventing the door from unlocking.
Mar 09, 2008 | Kitchen Ranges
F7
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
LG LRE30451 Electric Kitchen Range Logo
844 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
