Question about Protron PLTV3250 32 in. LCD Television
The tv wont turn on
I was watching my tv and then all of a sudden the tv turned off and now it wont turn back on...i tried to replug it in, pushing the power button, changing the batteries in the remote (the obvious stuff) so yea im not sure what to do
  • 11,361 Answers
Failed power supply is very common problem with this TV.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Posted on Jul 04, 2010
    Sniper:
  • 72 Answers
There is a main line fuse on the power supply of your TV that could blow when hit with a surge. This is one of many possible causes of a "dead set". The power supply could be working just fine but the micro is not operating so it will do nothing. If you lose the supply to the keypad that controls the power button and the IR receiver you will also not be able to turn the TV on and the TV just sits there. Check the electrical outlet with another device first to make sure it is on. It's an easy check that you can do without paying for a technician. If it's good then you will need a technician to take a look at what could have caused it to fail. The literature available on this model is not too great so it might be hard to really pinpoint. The first thing I would ask is how it went out. If it gradually became harder to turn on, having to hit the power button a few times or having to unplug and plug back in then I would immediately start suspecting capacitors on the power supply. I would visually inspect them for any dome topped caps and replace them with the value printed on them. If not then I would find the line fuse and make sure it is closed.
Best Regards,
Beach TV Repair
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
RCA 36695BC wont turn on
Can you please provide the chassis number of this TV?
Jul 24, 2008 | RCA F36695BC 36" TV
WE WERE WATCHING TV AND IT JUST TURNED OFF BY ITS SELF. WE UNPLUGGED ALL CORDS IN BACK FOR A FEW MINUTES AND IT STILL WONT GO BACK ON. THE RED LIGHT ON THE BOTTOM WONT EVEN GO ON. PLEASE HELP. THIS NEVER...
Tries tv unplug,replug it back like about an hour later.Tv now will be resetting itself back to the factory setting.Now the tv should be working again.If still have the same result than the tv power supply board is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2011 | Televison & Video
Last night I was watching TV just fine. I turned off the TV when I went to bed and then tried to turn it back on this morning when I got up. It wont turn back on and I have checked to make sure that there...
Check ur power source?Tries tv unplug,replug the tv back like about an hour later.Now the tv are resetting it self back to the factory setting.The tv should work now.If still have the same problems,some how ur power supply board is causes and is not providing the tv the wright voltages anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
TV set doesn't change channels or turns off.
UNPLUG THE SET FOR A MINUTE AND REPLUG AND TURN ON SEE IF THE UNIT RESETS. IF PROBLEM PERSISTS HAVE IT SERVICED. THE BUS MESSAGE IS TELLING US THAT THE COMMUNICATION BETWEEN SEVERAL IC' IS MISSING.
30 YR SERVICER
APGONZO
Jan 12, 2009 | Televison & Video
ESA 42' plasma turned off on it's own and won't turn back on.
I think, when a power supply's time is up, it's up now. There is not usually any advance warning,(besides your warranty has expired of course). If you are feeling un-normal heat from the TV, that is a sign the power board just fried out. They always get very hot, from the microchips cooking themselves until there is nothing left to need power. Plan on paying a TV tech to replace your power board.
Nov 13, 2008 | Televison & Video
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Protron PLTV3250 32 in. LCD Television Logo
923 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
