Question about Cameras
I have installed the driver and photo software for my Sharper Image 35 mm slide & negative converter model #50134SI and the computer indicates that the scanner is working. When I place the slide tray into the scanner the "ready" light is green but the "copy" light is red. When I attempt to aquire images from the scanner using the photo software nothing happens. Can you give me advice?
  • 130 Answers
SOURCE: No Image on display screen
Does the play back show any of the pictures you have taken before? are you sure the little lens cover is opening? there is a shield that closes down to keep the lens protected from debris and finger prints. Sometimes they can get jammed and not open. Tap on the front of the lens see if it opens. Switch it to auto mode if its not in auto mode.
Posted on Apr 05, 2006
jackboy
  • 2985 Answers
SOURCE: Pacific Image 1800u scanner and XP pro compatiability problems ?
If it is loaded and running then that side is OK. It seems to be a firmware breakdown in the scanner. Checkout the makers website
Posted on Aug 02, 2007
jackboy
  • 2985 Answers
SOURCE: Finepix viewer
The simple answer for all digital camera users that have installed the supplied software is
Remove it.
Windows can do the job mach better.
The windows camera/scanner wizard asking you what to do- you tell it it does it simple huh!
Posted on Jan 15, 2008
SOURCE: Sharper Image Digital KeyChain
The software on the CD never worked for me but when I downloaded the software from the website it's worked perfect...
Posted on Aug 27, 2008
SOURCE: need software for digital photo key chain
Check out their web page at www.mscustomercare.com. You can find the SW there.
Posted on Dec 28, 2008
Need an driver update to Windows 7
Most VISTA software and drivers will work with Windows 7. If you get an error trying to load it, it may be because the installer looks for the OS identifier and it is not XP or VISTA. IF that happens, you can right click on the installer file/icon, and select "compatibilty mode" for VISTA to attempt to make it work. This is rarely necessary, however.
Aug 31, 2016 | Jobar RX Optics 35 MM Negative and Slide...
Is there a driver for Mac OSX (10.11.3)
The manufacture would be the primary source if a driver does exist.
Apr 04, 2016 | Jobar RX Optics 35 MM Negative and Slide...
Where can I locate a driver download for a sharper image 50134SI
I have the original disc for this scanner. Email timetourst@yahoo.com for details on how to get.
Apr 15, 2013 | Tablets & eReaders
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
I would like to know whether there is some sort of attachment available to copy my photo slides and photo negatives to my PC?
There are several options but the most practical one is to get a scanner that scans transparencies. They are not cheap but are the most effective. Another option is to project the slides onto a special screen and then photograph them with a digital camera. This can be done with 35 mm negatives as well and then they can be turned into positives with software.
Jun 25, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
How do I scan 35 mm slides on my C3180 all in one printer/scanner?
Scan specifications
? Image editor included
? Integrated OCR software automatically converts scanned text to editable text (if installed)
? Twain-compliant interface
? Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
? Color: 48-bit color, 8-bit grayscale (256 levels of gray)
? Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Aug 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
Jan 16, 2009 | HP Photosmart Photo Film Scanner (35 mm)
Jul 31, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Cameras Logo
137 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
