By Lizzy - usenet poster
I am using the standard SoundMAX 4 XL with AudioESP audio subsystem using
the Analog Devices AD1985 codec that came equipped with this mobo.
After having done this, I achieve little sound. I am using my old HP Polk
speakers for sound. When I turn up the volume all the way, I can barely hear
the sound.
Anyone know what I should do next?
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 12, 2008
dont have sound
Comment by farrukh, posted on Nov 22, 2007
i needs sound driver
Best Solution
posted on Aug 10, 2005
Mini Me - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Yeah. This is an amplication issue indeed. The Intel docs for this board
state clearly that the line out port supports ONLY amplified speakers.
SEE BELOW:
"Note
The back panel audio line out connector is designed to power headphones
or amplified speakers only. Poor audio quality occurs if passive
(non-amplified) speakers are connected to this output."
http://www.intel.com/design/mo therbd/bf/bf_con.htm#8
Newbius
Posted via http://www.mcse.ms
View this thread: http://www.mcse.ms/message1283 231.html
SEE BELOW:
"Note
Newbius
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Rachel007 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Ironically, I've just installed XP on this board and have precisely the
same problem. I see you are using two old speakers. Are they amplified?
Mine are not. They worked well with my sound card in another machine,
but with this board and its on board card they produce very little
sound. I think you and I are probably dealing with an amplification
issue. I am about to plug in a few amped speakers and will report what
I find.
I am also downloading the latest drivers from Intel, though after
reading your post I do not think this will help much.
-Newb
Newbius
I find.
-Newb
Newbius
Suggest a new solution for this problem
Post a New problem for Intel D865GBF Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Diagrama de MotherBoard Intel...
Necesito el dibujo, diagrama,... Answer This...
Repair Service
Find Motherboard Repairman Near You:
