Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
I have a westinghouse lcd monitor, model : LCM-20v5. It was working fine, then one day when I turned on my PC, it displayed the desktop for about 5 seconds then went black. If I restart my PC, it happens again. How do I fix this?
  • 942 Answers
Hi! I do understand that you are having the problem with the monitor. Try to remove the cables on the monitor and turn off your laptop. Then remove the remaining cables on the desktop. Then press and hold the power button on the desktop for 8 seconds. Then reinsert the cables on the desktop and on the monitor also. Turn on the pc and if you still have the same issue, try to use another compatible cable to your monitor. Then make sure the monitor is turned on. There are few things to consider in this issue. Is monitor cable has loose ports? Meaning to say if you connect the monitor port to the desktop, there might be some pins that are bent. You can check it by inspecting the cable connectors. Otherwise, the LCD circuitry inside your monitor is busted. That is the time to call the manufacturer and replace the monitor. You might as well try a different desktop CPU to further isolate the problem. It might be a possiblity that your CPU desktop is not responding. You can check the lights if it is green , yellow or off. I hope this helps...
Posted on Jul 04, 2010
My Westinghouse LCM 19v5 will not powerup
Look for bad caps with bulging tops, similar to the 19" version as shown here:
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/Westinghouse%20LCM-20V5/
Make sure to use correct type caps for switching power supply.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
The screen goes on for a second and then turns off. If I then turn the power on and off numerous times it eventually stays on. I put the screen off to 60 minutes. Every time the screen is allowed to turn...
Hello Geoff,
The problem you are having is caused by a power supply board that is failing. Your monitor uses the Delta DAC-12M033 power supply board. We have a repair guide for the Westinghouse LCM-20V5 monitor that uses the same power supply board posted o our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ Check out the web article, it should get you back going again. If you don't want to do the repair yourself we do offer a repair service. We can get deatils on this service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 26, 2010 | ViewSonic VG2021m LCD Monitor
My Viewsonic VG2021m Monitor recently cut out every 5 or so seconds (the display came up and then went off) again and again and now it seems as though i cant turn it on at all even though the blue on light...
The intermittent image, dark picture or no power are all indications of a failing power supply. If you can solder you should be able to repair your monitor. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ The post is about repairing the Westinghouse LCM-20V5 but they both use the same power supply board, the Delta DAC-12M033 so the information is the same. If you don't want to do the repair yourself we do offer a repair service for this model for $32 plus return shipping. More information on this service can be found here. http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 19, 2010 | ViewSonic VG2021m LCD Monitor
Does not power up freind thinks it's a blown capacitor
Yes, it can be that and other components.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE (LCM-20V5 may be thesame chssis as yours) and monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Westinghouse LCM-19v5 Monitor
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
Black screen after a brief windows loggin screen
Hello
It's either the backlight, the inverter or the power supply. My shop would charge $50.00 + parts + shipping. I've repaired alot of Westinghouse monitors and I haven't junked one yet.
Jul 28, 2009 | Westinghouse L2046NV Monitor
Westinghouse Monitor Repair
you can look for other caps that are bad on the board that may have failed later.
hear is a list of replacements for all the caps on the 20v5 i have
http://www.fixya.com/support/t2576306-two_westinghouse_20v5_monitors_also_just
Apr 01, 2009 | Westinghouse LCM-19v5 Monitor
Monitor works for a fraction of a second
See article written by sillybit (me) for the Westinghouse 19v5. My 20v5 had bad caps in the power supply - it did the exact same thing as yours. $8 worth of parts from radioshack and an hour or two is all mine needed.
Aug 01, 2008 | Westinghouse LCM-19v5 Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
128 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
