Question about Sansui HDLCD3210 32 in. LCD TV
Tv picture goes out after 2 or 3 secounds but audio still works
  • Sansui Master
  • 8,457 Answers
The 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these refurbishes long LCD inverters boards for the replacement.
Posted on Jul 04, 2010
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
The picture goes blank after about 3 or 4 minutes. I have to shut it off and wait a few seconds and turn it back on. It does this 3 or 4 times and then it seems to stay on.
When the picture go black,tv still have audio?Yes,than those 1 or 2 long boards that call the LCD inverter boards are the problems are dying.If picture goes black and no audio at all?Yes,than the tv Tuner signal board have problems is dying.The tv Tuner signal board it is the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shojimmy.com,Ebay.com to buy those 1 or 2 refurbish long LCD inverter boards or the tv Tuner signal board for the replacement.
Mar 02, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My sharp tv is pc ready. I hook everything up and nothing works. Tried hdmi and also tried RGB-vga cables. If I put cable in hdmi port nothing happens. If I use RGB cable and audio nothing happens. If I...
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Mar 12, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
Tv trys to start. you'll hear audio for two secounds, no picture, then 8 flashing lights, repeats after a few secounds 8 more flashes etc,etc
There is a problem in the audio circuit or the high voltage circuits. Check IC406 audio amp, PS401, and 402. Check also the flyback transformer T8005 or the associative components around it or associated with the high voltage circuits on the D board. Try also unplugging the unit for an hour to allow the unit to reset and make the unit work. It sometimes resolves start-up issues with the unit.
Oct 27, 2009 | Sony KP-51WS510 51" Rear Projection...
Turn on
u may have a bad convergence ic and 2 pico fuse on the power supply , this type of work is recomende to be than by a tv repair shop
May 08, 2009 | Mitsubishi WS-55819 55" Rear Projection...
No Picture but Audio is present
suspect graphics bourd may be a dry joint if it comes and goes
Mar 15, 2008 | LG 42PX5D 42 in. Plasma HDTV
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
Sansui HDLCD3210 32 in. LCD TV Logo
211 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
