Question about Refrigerators
How do i remove the handle of my whirlpool fridge?
I have a new whirlpool 20.5 cu fridge. I want to change the handle from left to right. I can do everything necessary except I can't figure out how to get the handle off to make the change.
There are no visible pins or opening on the handle to get to the screws that hold the handle in place.
Suggestions? This is a bottom freezer refrigerator.
  • Kevin Dec 14, 2012
    You dont need a new door.
Firmly grasp the handle with one hand and put your other hand on top of the door and push the handle up. Took me awhile but I just figured it out. I just changed everything and it worked out great. Good luck.
Posted on Dec 14, 2012
    President:
  • 2,702 Answers
You may need a new door,,or use the top door just up-end it and put it on the bottom?
Posted on Jul 04, 2010
Whirlpool refrigerator door reversal
Check with supplier first but almost all fridge bodies are made for reversal
Apr 22, 2012 | Whirlpool Refrigerators
I have a side by side whirlpool water filteration system fridge and I need to know how to replace the water filter on the fridge
I can only guess because I don't know your model number. At the bottom of the fridge at the front there should be a round knob or handle about 2 to 21/2 inches, you should be able to turn this and pull out the long filter tube, take the number off it and get a new one.
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Handle on fridge side is loose
Look at the top and bottom of the handle. There should be a plastic end cap you can gently pry off exposing the screws to remove and tighten the handle.
Oct 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My side by side refrigerator handles are loose (Whirlpool gold)
Hi, Most newer models have a screw behind the plastic cover on the handle. Take a good look at the handle and see if the cover can be removed. It should just snap on. If not, please get me you model # and I can assist you further.
Thanks
Vic
May 14, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Can you change the handle on fridge? from left to right
Yes you change which side you want the handle You have to remove the plugs that are at the top of the fridge and at the the top of the doors. And also at the bottom. Exactly where you have the dorrs conected now look at the opposite side and in the same positions you will find these plugs. Just remove them and reverse them to the oteh side. I hope this helps. Don't forget to rate my answer, thanks
Feb 15, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Dec 17, 2008 | Whirlpool GB2SHDXP Bottom Freezer...
Refrigerators Logo
294 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
