Question about Samsung RS2534 Side by Side Refrigerator
Fridge temp light is blinking.
The model is RS2534WW. The fridge temp light keeps blinking. The freezer temp light is fine. We tried to reset the temp and hit power cool, but the light is still blinking. The temp inside the fridge appears to be getting warmer.
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
  • 150 Answers
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
Posted on May 08, 2008
SOURCE: Fridge not cooling
problem is this my fridge is not defro his freezer ice coil is icee and he is not stingworking. fridge is totly heat his freezer fan is run and he did not work. when i clean his icee coil with water he work well please tell me what i do. my fridge model is rg s462qvc pl pl any one who knows tell me thank,s alot
Posted on Jul 15, 2008
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
Posted on Nov 11, 2008
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
Samsung freezer not working light blinking but fridge is working
There must be lot of dirt and dust on the coolant tubes running from compressor in the rear. To solve that...do the following.
Disconnect the refrigerator. Pull it out so you can access the rear bottom end of the fridge where you can go to the black compressor. You will find tiny tubes running on black flat curved sheets. Feel the tubes and clean the entire area with cleaning solution or water with a damp cloth. After cleaning and drying, connect the electricity and the fridge will work fine.
Sep 11, 2014 | Refrigerators
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Freezer side of my RS2534WW Samsung is not working, fridge side is fine, evap coil fan is running,,, what could be wrong , it's only 7 years old
Your indications does not make sense! Your unit has ONE compressor that uses ONE evaporator coil to cool both sides. So if the FREEZER side is not cooling the fridge side should not cool either! Are you sure you don't have the freezer and refrigerator sides reversed?
Aug 14, 2011 | Samsung RS2534 Side by Side Refrigerator
THE FREEZER WORKS FINE THE THE FRIDGE LIGHT ITS BLINKING AND STAYS AT TEMP @ 66 WHAT CAN I DO?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
229 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
