Question about Peg Perego John Deere Gator HPX Ride on Toy
Where to charge the battery
Where do you hook the charger up on this product Perego HPX John Deere. I can't find the connection.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Posted on Jun 14, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
  • 670 Answers
SOURCE: We bought a Peg Perego john deere hpx. where can
You could try here. http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
  • 670 Answers
SOURCE: where do i find accessories for peg-perego john
Did you try here? http://tigerimports.net/sunshop/
  • 110 Answers
SOURCE: Where is the battary? Peg Perego John Deere Gator
the battery is behind the front bumper. There are tabs on either side in wheel wells to release the front end panel and it pivots downward to access the battery compartment. good luck!
Posted on Jan 28, 2011
  • 110 Answers
SOURCE: do the headlights on Peg Perego John Deere Gator
no, they are just for looks, but that would be cool to add leds and wire to simple battery or flashlight. in fact my son bungee'd a flashlight to his jeep last summer.
Posted on Jan 30, 2011
Where do you plug the charger to the john deere power wheels gator
you have to flip down the front brush guard and then you'll have access to the battery to disconnect it from the vehicle and connect it to the charger
Jun 27, 2014 | Peg Perego John Deere Gator HPX Ride on...
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Our john deere gator won't run
how do you know that the battery is charged? it could be that the charger isn't working. I would check the charger with a multimeter and verify that its putting out enough volts to charge the battery, it should be putting out between 13.8 and 14.6 volts
Apr 29, 2012 | Peg Perego John Deere Gator HPX
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
How do i access the battery to charge it up?
On a regular John Deere there are 2 small screws on the hood that must be removed and the hood lifts up. The battery has a cable that disconnects and the charger plugs into the end that goes to the battery. The connectors only go on one way, don't force it.
Hope this helps.
Here is a link to the page to download a manual:
http://us.pegperego.com/toys-catalog/2010/John+Deere+Gator+HPX
Thanks for using Fixya.
Dec 24, 2010 | Peg Perego John Deere Gator HPX Ride on...
How do i know if the battery is fully charged 12volt peg Perego battery
the charger's L.E.D. ... when plugged to the charger will glow GREEN if fully charged, YELLOW if charging, if it is charged and gator still is not working it is probably the shifter switch is bad, this is verycommon and fairly cheap and easy to fix(under 40.00)
Oct 26, 2010 | Peg Perego John Deere Gator HPX Ride on...
Old john deere gator and battery new charger still will not move
Dec 15, 2008 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
53 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
