Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod amp xm-1652z high level input connection
What do i connect to the high level input connector wires? is it the front right and rear right to one pair and left front and left rear to the other?
    Sergeant:
  • 300 Answers
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Posted on Apr 18, 2008
  • tech2166 Feb 03, 2011
    where would i get the connector that runs into the amplifier after i've spliced the wires? then would you run a crossover before or after the amp?
Have a '97 dodge ram truck with factory radio, how to install sony xplod amp?
You need a line level converter to connect to the speaker wires coming out of your Dodge stock radio. Like products from PAC, or Audio Control or specifically a Cache ClocD.
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Can i bridge a Sony Xm-1652Z 2 Channel amp to 2 subs it gives me 2ohms
No - it is not 2 ohm mono stable
  • 1000W max power
  • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
  • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
  • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
  • OTL (Output Transformerless) circuit
  • Pulse power supply
  • Line & High Level Inputs
  • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
  • 80 Hz, -18dB/octave Low Pass Filter Switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
What speaker componets do need to buy?
  • 1000W max power
And i would say that the best use of this amplifier would be for sub-woofers.
Feb 19, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a sony xplod 600 amp,hook it up,but the green light remains on,i have it hook to front speakers of my yaris,and i will hook the rear speakers to.why is the light on?
this is caused because the remote wire isnt unhooked. u either have to turn the remote wire off or connect the wires to the blue wires on the back o your radio for the light to turn off. that light WILL drain your battery fast!
Nov 23, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I need a high level input connector for a Sony Car Amplifier
best buy-wal mart-circuit city-ultimate electronics-radio shack- any stereo shop that deals with car audio-hope that helps look to spend between 12 and 35 dollars
Jun 18, 2009 | Sony XM-DS1600P5 Car Audio Amplifier
Sony amp model 1652z
1000W max power
<b>
</b>
Pulse power supply
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp connection
The speaker level input is designed to accept the speaker level signal from a head unit. This is generally no more than 20 watts RMS. If you drive the inputs with more than 20 watts, you risk damaging the input circuits of the amp.
Dec 28, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Well i need help with my amp./
If the amplifier doesn't have speaker level inputs, you will need to use a Line Output Converter (LOC) to convert the speaker level signal to a preamp level signal.
Dec 04, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Wireing
I believe that this model Sony amp includes High Level inputs. Those allow you to connect the normal speaker wires coming out of the factory stereo to the amp. If for some reason it doesn't include the inputs you can buy a high level to low lever converter that will give you rca from the factory unit.
May 06, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
1,855 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
