Question about Midland Two Way Radio
Midland GXT 950 two way. TX problem
Hi I am not sure if it is something that I am doing wrong but I cannot use my two way radios as when I push (and hold) the PTT button the TX only appears on the screen for a second before cutting out. The most you can hear is half a word. The problem exists for both sets. Are they faulty or do I have a setting incorrect?
Helen
I am sure the OP isn't likely monitoring this, but just in case anyone else needs it... It's a power problem. Try charging the batteries, even though they look like they're fully charged -- or replace with 4@AA batteries.
This only seems to happen on the GMRS channels -- not the FRS ones. The radios come default to transmit at high power (the full 5 watts) on the GMRS channels, but only 0.5 watts on FRS. If you go to settings and change the power on that particular channel you're trying to medium or low, you'd likely find it works with the charge you had problems with.
Recharging or changing to 4@AA batts should get you back up to continuous TX on those high-powered channels.
Posted on Apr 18, 2011
Cannot transmit, getting a constant tone while holding talk button and transmit light not coming on, any help?
Check the headset jack. There may be something inside causing a short. also, the CLS has an audio tone out button. Be certain you are not pressing it as you push the PTT button. The PTT is odd on this radio, it is the top BIG rubber button on top FRONT. Many customers get this confused with the tone transmit button.
Nov 13, 2015 | Motorola CLS1110 Professional 2-Way Radio...
Uniden uh038sx 2
Your radio is either stuck in VOX mode, or has a bad PTT button. Sometimes when using an audio device a radio will stick in Tx if the device is plugged in while the radio is turned on. When using any remote mic, earpiece, headset, or audio device be certain the radio is turned off when plugging or unplugging the device.
If no audio device is being used, the next possibility is a sticky or bad PTT button. This can sometimes be just the external button sticking, or it can be the internal button has simply worn out from repeated use.
One final thought, if your radio has programmable VOX, check to see if your programming is correct. VOX features when turned on make the radio Tx when it hears any sound, a voice or ambient noise can cause the radio to transmit.
Best regards.
Sep 28, 2013 | Uniden Hand Held Scanner - BC-246T 2-Way...
TRC 521, PTT button depressed, TX Led intermittantly Off. Press PTT several times TX led than works. Whats going on?
try some electrical component spray on the inside of the mic.Just a dash of it should do. not making good contact.
Mar 28, 2012 | Radio Shack TRC-521 CB Radio
My tx light is staying on ? so my base station is allowing everybody to hear whats being said in the office to the cars
Check your PTT (push to talk) button on your mic, and also double check the plug where it is connected to the radio. It sounds like your PTT is stuck.
Best regards.
Aug 22, 2011 | Radio Communications
To turn the tlk confirmation tone off... it does not work holding the - sign and turning it on now what?
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Oct 13, 2010 | Motorola Talkabout T6500 (7 Channels)...
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
My radio turn off after 1 minute in tx mode, how
If you are referring to when you hold down the PTT button for more than 60 sec. This function cannot be changed. It is self preservation of the final amplifier and other components in the radio. Transmitting longer than 60 seconds would damage/ruin the radio. (If this is not the issue please clarify.)
Best regards.
Feb 17, 2010 | Motorola Talkabout T5950 (7 Channels)...
CLS 1110 Programming
Not certain what order you are doing it, so I will type a brief explanation:
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming.
Mar 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
One radio not sending
hold the the ptt button for a minute in both handsets
Mar 07, 2009 | Motorola Talkabout FR50 (14 Channels)...
Squelch when keying ptt
I would check my ptt wiring making sure the button is set so that when you push it it switches you from RX to TX. If you have a wiring diagram that would be helpful if not are you able to get one? In any event make sure the wires are not misconnected.
Sep 12, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Midland   Two Way Radio Logo
1,244 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
