Question about Dell 926 All-In-One InkJet Printer
LED screen says "cover door open"
Printer does not work.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 308 Answers
When you do open the compartment by raising the top from where the paper comes out you should see a lever at the right side (colored blue) that comes out. That is what triggers the mechanism to show if the printer is opened or not. Check to see that it is doing its job well. It is the way out.
good luck
Posted on Jul 05, 2010
Rear cover jammed
Hi madeleine,
1.Press the cover release button and then open the front cover.
2.Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5.Using both hands, gently pull the jammed paper out of the fuser unit.
6.Put the drum unit and toner cartridge assembly back in the printer (press firmly).
Fully close the front and back covers.
Pull the duplex tray completely out of the printer.
7.Pull the the jammed paper out of the printer or the duplex tray.
8.Put the duplex tray back in the printer.
9. Make sure that the Back Cover LED and the Paper LED are off and then, the Status LED lights green.
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-5460CN All-In-One InkJet...
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But...
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But this doesnt work?
Apr 20, 2011 | Brother HL3040CN Laser Printer
Printer quit printing. Screen says fuser cover is open. Where is it located so I can close it?
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it.
LOCATION:The fuser cover is located in the back - its covered by the panel in the back called
the "back cover" aka "back output tray cover".
2-step fix:
(A) open the back cover - on the back of the printer.
HOW: it flips down
(B) open the fuser cover and remove paper jam
How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover.
(it also flips down to open).
Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Jan 01, 2011 | Brother DCP-7040 Laser Printer
ImageCLASS 2300 not printing, check printer cover message
Had the same problem spent 2 hours opening and closing everything trying to reset turn off and on etc. Here is how I fixed it, slammed all the doors on left side starting with above cartridge to cartridge door and 2 little doors by paper hard - and I mean hard - and whammo error cleared immediately. Sensors that check for open door obviously stick and report they are open when they are really closed. I am sure this saved me an expensive service call.
Apr 05, 2010 | Canon imageCLASS 2300 All-In-One Laser...
Turn on my brother hl 2170w printer -led lights up tone and drum yellow error is red and nothing else-doesnt even warm up there is no paper jam nothing-printer just sits there.
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Feb 09, 2010 | Brother HL-2170W Laser Printer
My printer is saying paper jam, but I can't find one
Have you opened up the top cover, removed all the cartridges etc?
Also paper can get stuck in the front door.
The sensor in the front door behind the manual feeder can get stuck down in the wrong position.
Feb 05, 2010 | OKI C3200n Led Printer
Alledged Paper Jam
Check underneath the toner/drums for the paper.
Oct 06, 2009 | OKI C3200n Led Printer
Printer would not run
open the front door thenremove ik cartridge then check there is not any paper jam.then restart the printer.
Jan 09, 2009 | Brother HL-2040 Laser Printer
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
Hp laserjet 1100 printer doesnt work
to open printer you need to remove screws. then two gray plastics parts on sides. cover on back should be removed then. front cover is similar, but front door first - unplug cover from two plastic sticks on top, then remove screw on bottom in hinges. be careful about wires.
Oct 16, 2008 | HP LaserJet 1100 Printer
Dell 926 All-In-One InkJet Printer Logo
59 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
