Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked , washer will not change settings and is staying locked and will not start
    Champion:
  • 274 Answers
Try unpluging it if this does not work try the start/pau botton
Posted on Jul 05, 2010
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
How to correct control locked will not go off on whirlpool ghw9150 washer
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
Sep 01, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My GE Front loading washer has a red lock light
On the GE GFWN1100LWW the Lock light indicates that the Child Lock (Panel Lock) is enabled. Press and hold the Lock touch pad for 3+ seconds. The light will go out. (Note: if you hold that button for too long, the lock will disengage and then reengage.)
The lock is useful to avoid having someone change the settings or start the washer when they shouldn't. (For example, you don't want to start or change the cycle settings on the washer while cleaning the control panel's surface.)
I hope this helps.
Nov 25, 2013 | GE GFWN1100LWW Washer
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Jun 28, 2011 | General Electric WCVH6800J Front Load...
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light stays on after load is finished.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please let me know. I hope this corrects the problem for you.
Mar 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control panel on my Whirlpool Duet model # GHW9100LW1 reads control locked. How do I get out of this?
There is a control lock so noone can start the washer washer or change your settings after starting the washer. There is a subscript under one of the option buttons that says (usually not very dark or prominant) Control Lock Hold for 3 seconds. Hold this button in for 3 seconds, sometimes slightly longer and the control lock should turn off. Most are not aware of this feature because it is never used. If this does not solve your problem unplug the washer for about five minutes and try again, if problem still persists please repost.
Thank you
Please rate this post
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not go on control locked light stays
You may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Wont start
if it is duet hold the end of the cyle button and it will re set
Dec 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
