Question about Garden
How do i adjust the chain on a john deere R70 lawn mower. the chain keeps on coming off the gear so i supose it needs adjusting.
rockitman187
  • 2559 Answers
SOURCE: throttle adjustment for john deere chain saw
The H is for high rpm (Main mixture) and the L is for Low rpm (Idle Mixture). First turn in both screws all the way in and then turn them both out 1 and a half turns. Pump the primer bulb if the equipment has one. Start the engine, once it is idling, turn the L (Idle Mixture) screw out (counterclockwise) from the preliminary setting until the engine speed decreases (rich). Note the position of the needle. Now turn the adjusting needle in (clockwise). The engine speed may increase, then it will decrease as the needle is turned in (lean). Note the position of the needle. Set the adjusting needle midway between the rich and lean settings as in the picture below. Don't touch the throttle during this procedure. Once you have found the best idle speed for the engine then you need to adjust the high rpm. This process is the same as with the idle rpm process but you need the to hold the throttle wide open while you are adjusting the H (Main Mixture) needle on the carburetor.
Please rate this a fixya
Posted on May 11, 2009
  • 20 Answers
SOURCE: john deere chain saw CS 56 idle adjustment
check the choke lever rod possable loose or off
Posted on Feb 11, 2010
SOURCE: We have a John Deere lawn mower model JS45. Just
this problem is related to the auto-snesing carburator. If you wrap the throttle cable, that runs down the left side of the mower, around the handle several times and tie wrap in place the mower will run. I had the same issue with mine. the manual is vague at best when it describes how to fix. After you wrap the cable around the handle, it will tighten the cable and the mower will run.
JV
Posted on May 05, 2010
SOURCE: i need to run the mower deck belt on my john deere...
I have to replace my broken belt on my L110 John Deere mower. I have the new belt in my hand...
Posted on May 25, 2010
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
How do you adjust the brake on a John Deere L100 Lawn mower
It fairly simple to adjust the brakes but there is two pins that tend to seize up that might giving your problems.
The brake is done by turning item 8 circled in Red. Right hand side of the transmission.
Feb 21, 2015 | John Deere L100 Series
How to adjust the valves on a la175
that is a lawn mower number, not the engine. But if it's a John Deere LA175 and it has a Briggs single cylinder you need to adjust them to .004 ~ .006. As for how to do it. You need a manual because I am not typing all of that up
Sep 10, 2014 | John Deere Garden
How to adjust transmission chain adjustment on r72 john deere
First verify the number of links. 102 links of number 420 chain including the master link.
Check the condition of the sprockets. Badly worn sprocket teeth will cause loose chains. Other than look to see if the mounting area are slotted so thing be moved a little apart.
Aug 19, 2014 | John Deere Garden
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
John deere 14sb
transmission is stuck in 5th gear the shifter pawl in the trans is most likely broken
Oct 08, 2013 | Garden
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Aug 09, 2009 | Garden
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
