Question about Audiovox D1718PK Portable DVD Player with Screen
Dvd player stopped working. I put dvd in and it starts turning and says loading and then says no disc & stops turning.
    Genius:
  • 1,456 Answers
Hi there
Two things can cause the problem you are experiencing,
1.the dvd you are trying to play is bad or
2. the lens of your dvd player is bad
What you should do is to try playing several dvd's to see if they work,if they all do then the particular dvd you are trying to play is bad
If some do not play then the lens is bad ad you should open up the dvd player and clean the lens with a cotton wool dabbed in a little bit of methylated spirit
after cleaning,test the dvd again to see if it plays.
If the problem occurs again,the best solution is to replace the lens of the player because it has become too weak..
Posted on Jul 04, 2010
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Apr 22, 2009 | Audiovox D1917
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Insert dvd, starts to spin up and stops, starts, stops, starts......and then is silent
I have the same problem. when i put in a disc while holding down the little button that makes it think it's closed, it starts to spin and if i keep on spinning it it will say loading until i stop spinning it, then it just says no disc.
Jul 16, 2008 | Televison & Video
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
DVD player stopped working
clear its lense.if it is in warranty replace by the company
Feb 01, 2008 | Mintek LCD TV Progressive Scan DVD Player
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Audiovox D1718PK Portable DVD Player with Screen Logo
114 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
