Question about HP Compaq Presario F730US Notebook
Wireless quit working, reinstalled windows and worked until i uninstalled a few "junk" programs(preloaded from manufacturer). will not see card in device manager. replaced card, updated driver and now when i put it into hibernation it shuts down. this just started out of the blue.
  • 808 Answers
Use reginout regcleaner to fix ur problem
Posted on Aug 19, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
If your internet is working wired using the laptop , i would advice you to download a drivermax , its a free program you can use to check if the laptop is missing some drivers. Ive been using it for quite some time now and its been very helpful whenever i format my laptops and desktop
Cheers,
KJ
Posted on Jul 05, 2010
How do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
Mar 12, 2013 | Acer Aspire 5536-5224 Notebook
I have IBM thinkpad R60 laptop . I got the laptop formatted few days back and loaded windows XP and MS office . after that the wireless radio is On all time . earlier after pressing fn and F5 th options...
Please follow these steps to make it work:
1. Uninstall the wireless driver using Add/Remove Programs
2. Uninstall the Hotkey utility using its Setup program (uninstall is an option in the Setup app; it doesn't appear in Add/Remove Programs control panel)
3. Restart
4. Delete the Hotkey folders from C:\Program Files\Lenovo\PkgMgr [key step!]
5. Reinstall the Hotkey Utility and the wireless driver (don't reboot if prompted)
Regards.
Jul 29, 2011 | Lenovo ThinkPad R60 Notebook
My linksys e1000 router works wirelessly with all my computers except my laptop which uses windows vista SP2, my network card is atheros ar5007, and my ISP is COX. I understand that the network driver is...
Most of the times you would be right when you say its a driver issue. :)
But there are certainly few steps that you can try as in -
a) Making an other third party program manage wireless on your XP SP2 machine
b) Tweaking the wireless channels to check if there is interference(this must have minimal impact as you already state that its working with everything else).
Try downloading a third part freeware to manage your wireless connections and uninstall the arheros client.
But before doing this try with windows client as well.
What is make and manufacturer of the XPSP2 machine??
Sam
Mar 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Having trouble uninstalling netgear wpn511
Need your version of MS Windows (or are you using Linux or Apple OS?), anyway, assuming
MSWin XP or WinVista or Win7,
start > control panel > add or remove programs > (L-click) Netgear software > (select) "Uninstall"
but if these vanilla instructions have been tried & aren't working, you may need to do a "system
resore" to a recent system configuration that worked well, then uninstall there, then re-install
all the stuff you're missing by doing a system restore...... if you've installed alota stuff recently
(like me) this could be very painful, and you won't know how far back to go until an uninstall works.
From the Netgear WPN511 RangeMax reference manual
avail from: ftp://downloads.netgear.com/files/WPN511_UM_03Feb07.pdf
Removing the WPN511 Software
If necessary, you can remove the wireless adapter software in these two ways:
• Navigate the Windows Start menu to the WPN511 Wireless PC Card program group, select the
uninstall option, and follow the screen prompts.
• Navigate the Windows Start menu to the Control Panel Add or Remove Program item, select
the WPN511 Wireless PC Card option, and follow the screen prompts.
If your system is acting unreliable and/underperforming in other ways, suspect a virus/worm/trojan
and clean out your system with Avast!/Norton/AVG/Kaspersky/McAfee, etc. then try the
uninstall again.
Dec 27, 2010 | NetGear WPN511 RangeMax Wireless PC...
Web Pages Have stopped loading completely
Norton is the problem, try and update your wireless drivers. If this doesn't work, go to the device driver and uninstall the wireless card, reboot the machine and that will force windows to load a fresh driver to the card. If windows asks to search windows update, allow it and let it complete the install, while you are doing this make sure you are connected to the router via a cable. good luck. If none of that works, you may try going to Norton and getting their Norton Removal Tool, this is the only way to truly rid the computer of this program and Norton has been known to "out of the blue" make wireless useless.
Oct 03, 2009 | Dell Inspiron 9300 PC Notebook
I am using the Logitech A-0356A headset. I can hear windows sounds, but I lose the sound in IE and programs, games and incoming voice in ventrilo. This just started recently, I have had the headphones for...
sounds like issues with the codec of the sound card may be interfering with program communicating with other devices, uninstall your sound card and try rebooting the pc. if the sound card is having issues then reinstalling should clear them up.
if issue persists look into updating the sound card drivers through the pc manufacturers websight.
Jul 19, 2009 | Logitech 250 Headset
Acer Travelmate 2300 and wireless
Uninstalled all the driver you have right now
Try finding the model # of your wireless card and find the specific driver for it, It would resolve the problem
May 30, 2009 | Acer TravelMate 2300 Notebook
Mouse Not Working in XP
the very first thing what u have to do is uninstall and reinstall the driver for the wireless mouse and then restart the computer and still if it doesnt work try it with some other computer which has xp sp3 and it it works with the other computer have the same windows os then uninstall and reinstall the wireless driver also,and if it doesnt work with the other computer also then replace the wireless mouse.but before that always check ur wireless connection with the wireles mouse and also check the lights on the mouse..and what u can do is call up dell and tell thatm to replace it for u or for complete solution u can call up cyyberdefender.com for premium tech support.......take care ...
Jan 23, 2009 | Microsoft Wireless Optical Mouse
Stopped connecting to internet through land line
hi there, i had kind a same problem with u, the only difference is mine shows "connected" but i can't surf the internet when others in my network are doing just fine. 1st i tried to uninstall my LAN card driver and the reinstall it back. It worked, i can surf the internet but only for a few minutes. So i installed a firewall, in my case, i installed windows defender. After reinstalling my LAN card driver, i realized an unknown program tried to change some of my LAN driver files, so i denied the program access using windows defender. The problem solved !! Maybe it's a virus or spyware, i don't know because before installing windows defender, my avg and antispyware don't detect any virus/spyware. Hope this help, gud luck
Sep 26, 2008 | Acer Aspire 9300 Notebook
Wireless WLAN
I have been working with Dell on this problem for quite some time. They tried replacing drivers, uninstalling and re-installing the card, replacing the card with a new one, etc, etc. Nothing worked. Sooner or later the error came back. Their last "fix" was to suggest that I restore the system to factory default condition and start all over again. I refused to do this. I had spent over 8 months adding software, tweaking it and windows, etc. They basically threw up their hands and gave up.
The Dell tech who replaced the card tried the solution noted here and "supposedly" it was fixed. A few weeks later the error came back.
So... I still don't have a fix for this problem.
If anyone finds one please let me know.
I'll check back here periodically.
Thanx,
Randy
Jun 08, 2008 | Computers & Internet
HP Compaq Presario F730US Notebook Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
