Question about Refrigerators
Our Kenmore Elite Bottom Freezer, model no. 795-751-96400 isn't making ice cubes anymore and the refrigerator is too cold. The digital display no longer works. Any solutions?
  • jjtmmoore Jul 04, 2010
    Our Kenmore Elite Bottom Freezer is too cold in the refrigerator. The freezer is working fine. The model no. is 795-751-96400
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to have a detailed view regarding your query…..Follow the testing and troubleshooting instructions of this linked page and see what you come up with:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Also the solenoids in the valve- the one controlling water to the ice machine had stopped working. A good test is to pour water into where the ice cubes are made. If ice cubes come out then the problem is most likely in the valve.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 05, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
  • 2 more comments
    Our main concern is that the refrigerator is too cold. Would that be caused by the control board going bad?
  • Rylee Smith
    Rylee Smith Jul 04, 2010
    Yeah...Thats why I said to test it first...
    The ice maker has an "on/off" switch, not a lever. How do we test the 120VAC in this case?
    Also, the refrigerator was too cold before the ice maker stopped working...
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refrigerater is not cold. but the freezer is working fine. what can be wrong
You have a defrost problem Need model number to see who made your frig as Kenmore makes nothing.
Nov 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
