Question about Whirlpool GEW9250 Electric Dryer
When I turn the dryer on it sounds like a constant squeek.
The sound is high pitched but I dont believe it is just the belt, sounds like a bearing or a pulley. The noise is louder on the front left of the unit. We purchased it about two years ago.
  • 760 Answers
Posted on Jul 05, 2010
RCA ctc195 series won't power on constant small beeping sound
if its a high pitched squeek its a short in the deflection circuit, a common failure part here was the high voltage transformer.
Dec 11, 2012 | Televison & Video
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
Whirlpool model LEQ8800 - squeeks when running, periodic in nature (1 squeek per revolution), sort of like a high pitched chirp; louder and longer when fully loaded. Is this a bearing (that needs to be...
he belt tensioner has a roller with a bearing in the middle of it. that is your squeaking problem on every revolution it turns
replace the roller and belt sold as a kit at SEARS
Jun 10, 2010 | Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer squeeks a very high pitch sound when it is running
likely needs oiling on the main bearings? or in the electric motor? or the belt is worn out; not likely with a newer drier. Tear it apart and WD40 works great.
Dec 27, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My dryer is making a high pitch squeeking noise but it still dries.
You likely have an idler wheel that is dry. The idler wheels are what supports the drum and allows it to turn freely. There may also be a belt tension problem. If the belt is too lose, it can slip on the motor, causing a squeal as well. First thing to do is pull the housing off, and see exactly where sound is coming from.
Nov 02, 2009 | Maytag PYE2300AY Electric Dryer
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer modle #lde9334ace making noise
More than likely it is the belt. A simple fix is to spray some belt dressing on the belt. However, changing the belt would be the best solution. Good luck.
May 18, 2009 | Dryers
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
