Question about Toro& Electric String Trimmer
I can't unscrew the head to replace the line. I'm trying to twist in the direcion the arrow shows it will unlock, won't budge.
  • 8,197 Answers
May I get the model # so I can help you more.
Posted on Jul 05, 2010
Can not turn bolt to get head off to refill string for Murray N2510
it could be a left handed bolt . many string heads are so they sty tight in use .
May 26, 2016 | Garden
97x plug removal? Pulled on wires to manifold and did not budge. Are these any different that regular wires? I even tried with pair of pliers and got scared that I might damaged the wires
Try to twist or rotate like trying to unscrew the wire.they get stuck to the plug and need to break the "bond" by twisting you will feel the sticky pop and release.when you go back together use silicone that they make for plug wires to keep it from sticking again. Good luck.
Oct 31, 2013 | Cars & Trucks
Customerservice
yes it does unscrew it will be tight and you will need alot of presure to unscrew try tapping it with a screwdriver handle turnig it the link below is the manual page 10 is filter change.
http://hoover.com/file/979/http://hoover.com/file/979/
Jul 26, 2013 | Hoover Vacuums
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
Trimmer head line loading instruction
Jun 29, 2011 | Husqvarna 28cc Gas Line Trimmer
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
How in the bloody hell do I change this 'quick change spool' on my z03 omega? I can't seem to figure it out for the life of me...
Unscrew the front cone. While holding the handle unscrew the spinner head and remove from the reel. The quick change spool will have an arrow to show the direction that you twist it off. That's about all their is to it.
May 24, 2011 | Zebco Omega Spincast Reel
Need to know how to change break light bulb
Open the truck & remove philips head screw that is located to the left of the tail light housing in the trunk lid weatherstripping housing area. Next unscrew the trunk lining screw to fold back the trunk lining to get at the two plastic wing nuts that hold the light housing.
Unscrew these two wing nuts and slide the housing out, then remove the bulbs and replace. Bulbs come out similarly to how you'd replace the front headlight bulbs (unplug, twist counter-clockwise to unlock and remove old bulb, replace with new bulb and turn clockwise to lock, plug back in).
Oct 16, 2010 | 2006 Chevrolet Malibu
Toro& Electric String Trimmer Logo
436 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
