Question about Goodman CLQ36AR49 Air Conditioner
My Goodman ac unit is still running but it just feels like the fan not ac. We don't know the problem but guessing the dual Air conditioning/heat Pump (CapacitorGSC130421AC) is bad. Please advise! Thank you for your help!
  • 407 Answers
If the fan motor on the outside condensing unit is running, but the compressor is not coming on, then yes, most of the time it is just a capacitor. It could also be the compressor has a short or bad valves. If the compressor comes on in the beginning, but shuts off while the fan motor is still running, then you could have a low/high charge, and the unit trips the internal overload switch because it overheats. Hope this helps.
Posted on Jul 11, 2010
The difference between the heat pump and condenser
Well...they are kinda the same. The condenser is where the refrigerant is condensed from a gas to a liquid. When in AC mode this happens outside at the AC unit. (You ever put your hand over a running AC unit in the summer? Feels warm!). When in Heat Pump mode the process is reversed. Instead of condensing the gas to liquid outside (which creates heat) the condensing happens inside and helps warm the building up (with the help of the fan of course). So essential the condenser is where the gas is condensed into a liquid, which creates heat. A heat pump can reverse the direction of the flow and cause this condensing to happen either outside or inside.
This is a very watered down version of what happens but I hope this is sufficient for what you are asking.
Jun 29, 2014 | Goodman Heating & Cooling
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
I have a Klimaire 16 Seer Dual Zone Mini Split Heat Pump AC and the outside unit fan/fan motor have stopped working where can I replace this at? I live near Dallas Tx surely there is something nearby?
You should check the fuses and breakers it might not be something that expensive, it could also be the controller for the outside unit that is bad. Google kllimare dealers and your zipcode.
Sep 02, 2013 | 18,000 BTU KSIM DUCTLESS MINI SPLIT...
I have two outside ac one for floor and other for upstairs and i button on heater auto and ac outside fan is running is that normal or not? and live on this new house for two years and cant find someone...
No the fan out side is for a condensing unit and compressor. The compressor should not run with the heat. I am almost positive that if this is not a heat pump that the compressor unit should not be running.
Dec 20, 2010 | Goodman GMS90703BXA Heater
Outside unit runs, air handler inside runs sometimes Is there a fan relay that will work sometime? can here freon circulating but fan will not run. Can cut off and restart, will come on sometime. ...
Their is a fan relay on combo gas heat and central air conditioning.
The reason is for heat you need slower fan speed than for air. How do they do it? They use a relay to shift the fan from low for to high for ac.
More HERE
Aug 03, 2010 | Goodman Heating & Cooling
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Outside unit will not come on
Check the starter capacitor, and di you remember to add oil?
Aug 27, 2009 | Goodman CLQ36AR49 Air Conditioner
I have Goodman combination heating and cooling outdoor unit PBB series. I am wanting to know if when the heat is on should the fan outside turn or is that only ac
If it's a heatpump, then yes the outdoor fan will turn unless the unit is going in defrost mode. But for the majority of the time a heat pump is operating in heat mode, the outdoor fan is running.
Jan 16, 2009 | Heating & Cooling
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
MY AIR CONDITION ONLY PUT OUT WARM AIR EVERYTHING SEEMS TO BE OK FILTER TURNS ON OK BUT THE OUTSIDE UNIT HUMS BUT DOES NOT FAN
Sounds like a bad start run capacitor. The exhaust fan motor may be bad too. Be careful, this unit delivers 220volts of electricity.
Jun 17, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
220 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
