Question about Canon imageCLASS MF5530 All-In-One Laser Printer
Imageclass mf5530 jams from paper tray, bypass
Canonj imageclass mf5530 jams from paper tray, bypass works ok
  • 1,219 Answers
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Posted on Jul 05, 2010
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Paper Jam Konica Minolta BHC451
Is the thick 4 11 x 81/2? take the paper off the bypass tray, first send the job to the copier selecting the bypass tray the copier is going to beep telling you replenish paper in the bypass when you place the paper in the bypass make you follow the orientation of the paper on the copier screen.Might also want o replace the bypass tray roller set. If the Plain paper through Thick 3 work then you did not need to replace the main board. Are trying to duplex the paper????? When it jams where does the paper stop??
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 16, 2017 | Konica Minolta Bizhub C451 Copier Print...
Need a operating manual for a Cannon ImageCLASS MF5530. I looked in the Cannon CO USA and they don't have one. Does any one know what site they can refer me too???????????"??
Here is a link to the operating manual for the Cannon ImageCLASS MF5530:
http://www.retrevo.com/d/ds/progress?doc=073e52d2f35d974f475350034be5f59e&u=1&rk=0.18132861234070663
Aug 24, 2011 | Office Equipment & Supplies
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
11x17 paper jams from drawer - will not feed from sheet bypass
Check to see if the actuator arm is stuck in the bypass tray,therefore not seeing the paper and be sure the side guides are up against the paper. If that doesn't work and you have 2 cassette cavaties put the 11 X 17 where the other tray is . Hope it works for you.
Apr 09, 2010 | Office Equipment & Supplies
Paper jam in front roller of imageclass D880 (about 1/3 inside)
dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Oct 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
Paper jam from bottom tray.
You might have a piece of paper out of sight. It usually is before the toner and after the pick up area. BEst to call 800-ok canon to find a local service center. This unit comes with a 3 year warranty, and you might still be covered.
Jul 09, 2008 | Canon ImageClass D861 Printer
Paper jam
Your best bet is to have a canon tech check this problem out. There are several causes for this issue; a bad delivery roller, a small piece of paper lodged out of sight. Canon help is 800 ok canon.
Canon imageCLASS MF5530 All-In-One Laser Printer Logo
145 people viewed this question
old marine
old marine
