Question about Jabra BT3030 Wireless Headset
Jabra bt 3030 paired but cannot use headset
In the sense that the bt3030 has already been added to the system {win7} but does not enable the blue tooth headset for the audio output..
  • 4,737 Answers
If I am right, you haven't paired the second device with it (your pc). Well follow the simple instructions;
First turn off Bt3030, and continue pushing the power button on the Bt3030 until you see the Jabra logo turns pink. Again keep pushing the power button after the Jabra logo became blue, now check whether it works or not.
If this doesn't work, please disconnect it's connection from the player and connect it to the pc. After it's connected with the pc, reconnect with the player as well.
In case this doesn't work, then your unit doesn't support dual channel.
Good luck.
Thanks for using FixYa.
Posted on Jul 04, 2010
My lg prime will not pair with my jabra bt3030 bluetooth headset
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra BT3030 Bluetooth Headset
I'm not able to pair my jabra BT3030 headset with my mobile. plz tell me the solution to this problem.
You must specify what type of phone, make and model. there are some phones that just will not sync with some headsets. I have actually owned a couple of phones that would not sync with my Jabra headset.
Jan 22, 2011 | Jabra BT3030 Wireless Headset
Connecting cell phone and Jabra
Check that both devices are BT enabled and in pairing mode -ie, leds blinking-. If one of the device is not in pairing mode, it is normal that the process fails.
If you experience the same problem on other phones with your Jabra BCE-250 -same as mine-, you might think of getting it checked first.
Dec 10, 2009 | Jabra BT250 Consumer Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
Jun 03, 2008 | Radio Communications
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Jabra BT3030 Wireless Headset Logo
201 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
