Question about Compaq Presario V4000 Notebook
My batter is wedged
And it will not come out. I took to a shop and there only suggestion was to pry it out, which probably cause damage. any other ideas?
    Genius:
  • 2,028 Answers
The best way to get at this is by taking the plastics apart. You want to get to a point that you can see the back of the battery so you can push it out instead of prying it. Start by removing the keyboard, then the top plastic that hold the touch pad and surrounds the keyboard. At this point you should be able to see the back side of the battery pretty well, make sure nothing has fallen into the battery bay that has made the battery kick off to one side. You should be able o work it out from there.
Posted on Jun 11, 2008
What specialty tool do I need to remove a PTO clutch that is stuck on spindle of a cub cadet.
if rusted lube and a dead blow mallet or hammer ----if wedged from damage heat and pry bars and hammers
Apr 12, 2017 | Garden
Doors locked how to unlock no keys
It's actually pretty easy and can be done in about 20 seconds for experienced people. They probably used an inflatable wedge to pry the side of your door open then used a long rod to unlock the door by either hitting the unlock button or by moving the lock selector switch at the handle. I hope they didn't take anything too valuable. Scott
Jan 26, 2013 | 2006 Dodge Ram 1500
How to remove the rear light assembly on 2007 Odyssey?
After removing the 2 screws take a soft rag and fold it over a small pry bar or screw driver and wedge it int the front of the housing closest to the front of the car and pry towards the rear DO NOT PRY TOWARDS THE FRONT be car full not to damage paint be gentle but firm it will come out they do make plastic pry tools the help with causing damage to paint or plastic but with a rag and a screw driver you can persuade it
Oct 15, 2012 | 2007 Honda Odyssey
I don't know how to remove battery from this phone. Help.
take the back of the phone off, the battery is nearly impossible to pry out til you get practice but use the rounded corner of the metal back that you took off and put it in the little space on the top of the battery and wedge it in and pry up. keep trying, it will get easier lol
Mar 31, 2011 | LG Shine KE970 Cellular Phone
1996 Toyota Camry LE. Took it to the shop to have the CV joints replaced, both of them. Mechanics are unable to get either side axles out of the transmission. They have tried using heat, impact hammer,...
There is a small "circlip"holding the axle in place. Place a pry bar between the cv joint and the transmission and pry the axle out with a sharp snapping movement. This should pop the axle loose from the "circlip". The steering wheel can be turned to gain more working room. Tell those guys to lay off the heat. Hopefully no damage was done and they will be able to get the new axles in without too much trouble. Merry Christmas.
Dec 24, 2010 | 1994 Toyota Camry
Existing vessel sink is stuck to polished granite vanity top. We want to replace the sink with a different one but can't get the sink to release--we originally used silicone adhesive and have tried wedging...
Silicone is an excellent adhesive once it is fully cured. I would not try to pry it off but I would suggest that you take the blade out of drywall or utility knife and carefully try to cut through it. It probably will take several cuts to get the old basin free but thats the only way I can think of to do it without damage to counter top. Hope that helps. Thanks
Nov 13, 2010 | Buck 31" Granite Vanity Top for Vessel...
1992 Mazda MX3 driver side cv axle won't come out. Took off nut axle stuck and won't come out. How can I get it out?
Get a good pry bar and wedge the bar between the CV shaft and where it goes into the tranny.You should be able to pop it out.If not rotate the shaft and repeat untill it lets go.It is only held in place by a round clip on the shaft inside the tranny.Be patient its been there a long time. Good Luck
Oct 24, 2010 | 1992 Mazda MX-3
Same problem with the pump-how do you get it off???
If you are careful you can but be careful while doing it as you can injure yourself or cause further damage to the machine. Can you get the pump cover off as I have found very often that a baby sock or wash cloth has wedged itself in the pump causing it not to work properly. After removing the plug and putting back together it has worked fine.
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Wedged Battery
you have to force it to remove your battery. in some extent it will be damage but you have to remove it in anyway.
Apr 17, 2008 | Compaq Presario V4000 Notebook
Compaq Presario V4000 Notebook Logo
21 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
