Question about Sony KV-32S42 32" TV
PICTURE GOES OFF AND ON WHILE TRYING TO WATCH SOMETHING
AT FIRST IT DID THAT WHEN YOU FIRST TURNED IT ON. Then when heated up it would stop but now it does it all the time
    Sniper:
  • 72 Answers
This could be a "White balance failure" and the probable cause locations listed are as follows:
1. Video OUT (IC9001-IC9003) is faulty (C board)
2. CRT drive (IC201) is faulty (A board)
3. G2 is improperly adjusted.
These are starting points for a qualified service technician. The most likely of the above is IC9001, since it is the RED-VIDEO OUT chip.
Best Regards,
Beach TV Repair
Posted on Jul 04, 2010
  • Sony Master
  • 1,210 Answers
I say for starters, you really should investigate the vertical IC. This is first of all, a very common problem in the Sony TV. You will find cracked rings on this chip, resoldering is the first step in solving the no raster audio only! The other thing to mention would be a faulty regulator. If you have an access to a variable transformer, please use it. You may discover at about 130 volts you will have a raster that is not wide enough to fill the screen. This would indicate a faulty horizontal regulator. And sometimes the audio IC will have a built in standby. In the Sony TV,a standby will act like a powerline regulator, This IC will shut this TV down eventually. Any of these problems will be present because you have bad capacitors. They will pull these ICs down.Remember these are only suggestions for now. The Sony TV is very complicated and you can use all the hints you can get. Thanks for asking!
Posted on Jul 06, 2010
Check whether the crt filament is glowing...there could be dry solders in 6.3v filament supply.
Posted on Sep 05, 2010
Since i last posted i have opened the inside of the oven and removed the back panel turned power back on and turned oven on element heats up fan goes ronnd and then stops why should it do that
Will the fan rotate freely if you push it with something or is it binding?
It could be as simple as the bearings needing to be oiled.
Sep 04, 2014 | Washing Machines
Thomson 50DSZ644. Just replaced the Lamp great picture but burned smell.. after few house it smelled verry bad..and i turned off. now when i turn on the tv the picture in middle is dark and still thi
should have unplugged it when you noticed the smell.
UNPLUG and remove and look at lamp you installed--is something in the housing where lamp goes melted? I hope you did not touch the face of the bulb with your hand or fingers.
What ever is wrong find it before trying to use set again.
Dec 22, 2012 | Thomson 50DSZ644 50" DLP Rear Projection...
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
My unit is running on heat but every 10 seconds makes a clickiing noise like something has been tripped. This is followed by a whooshing noise. My repair man says it's normal and the unit is trying not to...
trying not to freeze every 10seconds ha.it goes in defrost every 20mins . if something has been tripped it would fully stop and you would have to restart it at the circuit braker. its not the fan hitting something ? repair man is an air con mech? is it a box window unit?
Nov 09, 2010 | Goodman Heating & Cooling
RELACED WATCH BATTERY BUT WATCH STILL STOPS
The best place to take is a jewelery store or some place that can repair watches/replace batteries that has a cyclonic quartz watch tester b2164de.jpg A cyclonic can detect if there is a pulse (the electrical signal that makes the hands move) even if the hands don't move. It can also spin the gears/hands to unstick the gears if some debris is holding them up. If there is no signal the coil or something inside the watch may have been nicked or something else is wrong with the watch and may have to go to a watchmaker/repairer or replaced.
Oct 23, 2009 | Watches
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Won't Turn On
I bought a proscan tv about a months ago. yesterday it stopped working. The red button is on which shows that it is receiving power however, there is no picture nor sound.
Aug 27, 2007 | Proscan 19LA25Q 19 in. LCD Television
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
483 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
