Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
I have an old Thermador cv 136 electric cooktop with downdraft. I'd like to replace it with a gas cooktop. Does Thermador make a gas cooktop compatible with the old downdraft unit? (label on downdraft unit says its for models CV136 and CV336). Are any other brands compatible with this downdraft system. Thanks! Greg
5 Suggested Answers
SOURCE: Downdraft doesn't alway go down and up.
I have the same problem. Seems to be pretty common that the motor that raises the unit goes bad. Ours is 2 1/2 years old and has not seen that much use....that motor should not have failed that soon...and this is a high end product!!! I have been quoted $289 for a replacement motor and $150 for labor!! So, $450 bucks....gads. The unit, new, cost about $900, as I recall.
Posted on Nov 29, 2007
  • 4102 Answers
SOURCE: Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Posted on Feb 22, 2008
Mrvica
  • 167 Answers
this is ID 25898888.
alicantecoli
  • 22156 Answers
SOURCE: I have a 1989 model
check in the hood pipes for a rubber seal thats come adrift as something isloose or come apart allowing the hood to come too low so it passing the microswitch for the fan ,between teh tubes is a seal and suspect that one of these has collapsed allowing the hood to come down lower ,its a take it apart type job and see ?
Posted on Jan 17, 2011
Need new electric cooktop to work with downdraft CV2236N-01.
never heard of one needing downdraft usually updraft . gas maybe but not electric
Apr 12, 2014 | Maytag MGC5430 Gas Cooktop
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
Where do i get replacement electric burners for this cooktop
reliable parts .com / you can order on line . i get mine there .. mm
Nov 14, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Downdraft vent unit is stuck halfway.
You'll have to remove it and manually reverse the drive gear. Hopefully, it didn't get stripped.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
Mar 12, 2009 | Thermador REF30 Electric Kitchen Range
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Kitchen Ranges Logo
296 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
