Question about HP OfficeJet 6210 All-In-One InkJet Printer
My HP 6210 worked great, now no color even after lots of cleaning
My HP 6210 was working great then all of a sudden no color. Black prints terrific but even after cleaning the heads, 6 times the color stinks! Then when I think I have it fixed boom the next day it stops again and I have to go through the cleaning again; This is costing me $$$ in ink. what is wrong? Can't afford new printer.
  • oldkauaikuui Jul 05, 2010
    Yes, but the problem may still be there.
    President:
  • 3,278 Answers
Hello.
Give this a try - from HP Support:
(1) Open the printer
(2) Remove the color ink cartridge from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then the print head will need to be replaced.
Hope this helps.
Posted on Jul 04, 2010
  • 1 more comment
    ok, so now it works but what about tomorrow? I have done this before and the next day the problem is back.
    so now it works, but what about tomorrow? I have done this at least 3 times before and the next day the color does not print again. I have thrown away brand new cartridges thinking that would help.
  • NinaE Jul 05, 2010
    If it continues to be a problem, you'll probably need a new printhead. Sometimes service or printer replacement is the only alternative.
    Contact a service center in your area to evaluate if it would be cost-effective. Good luck.
My HP Officejet 6210 has a message reading "Remove
Check that the HP all-in-one print queue is not paused (Windows) or stopped (Macintosh). If it is, choose the appropriate setting to resume printing. For more information about accessing the print queue, see the documentation that came with the operating system installed on your computer.
Check the USB cable. If you are using an older cable, it might not be working properly. Try connecting it to another product to see if the USB cable works. If you experience problems, the USB cable might need to be replaced. Also verify that the cable does not exceed 3 meters (9.8 feet) in length.
Mar 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
I just loaded new HP 94 and HP 97 ink cartridges in my HP 6210 Officejet. I went through the alignment process and received a sheet that had colors, but no black ink. The printout indicated the alignment...
Make sure all the protective tape on the Black cartridge has been removed. Also are the inks re-filled? I have seen many re-filled cartridges fail in a similar maner.
Nov 22, 2010 | Computers & Internet
Can the ink cartridge HP 98 work on a 6210 HP Office jet?
No, it can't
The HP OfficeJet 6210 works with the following print cartridges:
Black: 94
Color: 95, 97
Photo: 99
Source: http://www.shopping.hp.com/supmodel/product/Q5801A
TechSaver!
Feb 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can I disable the color? It's empty but black is full
even if it is empty, most printers require that you have the color cartridge installed. you have to go into the printer settings and change it there to print only black copy.
Sep 18, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All-in-One: Black Ink Copy Problem
i've fixed a simular issue recently, it could be your print head has developed a issue\blockage for the nossles for the black ink tank, it could be mixing colours from word but a black white copy will just use the black ink, try removing the head and using isopropol on a qtip to clean the head for the black only.......
Aug 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP 6210 Color doesn't work; second new cartridge in two weeks
your cartridge is drying very fast if it is hardware ptoblem it means that cartridge parking is missing one of its part.
1. when your printer is off or it not in use their is a printer part of small rubber for covering your cartridge head in your printes cartridge parking thar rubber part is missin in your printer .
you may find it in side your printer it self.
Jun 02, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
