Question about Linksys WRT120N Router
Trying to set up computer with linksys wireless. Says it's unable to connect????
ImWireless
  • 113 Answers
SOURCE: connecting westell 6100 (verison) Vonage and linksys WRT53G 2.4 and computer
try this resolution provided by me earlier. In any case if this doesnt work, you may initiate a chat with me and we can carr on from there... http://www.fixya.com/support/t139545-configure_router Good luck
Posted on Apr 22, 2007
  • 51 Answers
SOURCE: unable to connect to the internet
Open your web browser. Type in 192.168.1.1 into the address bar A dialogue box will pop up. Leave the username field blank and the password is admin. Once the webpage is displayed, scroll down until you find Local IP Address. Change this to 192.168.2.1. Scroll down and click save settings. Now attempt to access the intnernet.
Posted on Dec 24, 2008
kakee
  • 1269 Answers
SOURCE: Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Posted on Jun 06, 2009
  • 117 Answers
SOURCE: unable to access linksys wireless router,with
Hello trinijazz,
To accomplish the setup of the router, you need to be using a computer that is connected directly, harwired, into the router itself. If you don't have two computers, use the laptop but connect it into the router using the ethernet port, and ensure that the wireless on the laptop is off.
Open up your browser window and Enter 192.168.1.1 in your browsers address bar, no HTTP or anything, just the numbers, and press enter. A login box will appear that is asking for a User Name and Password. They are both, in lower case: admin then click on Login. This will take you to the Linksys Setup screen.
You have tabs at the top/center of the screen.
1) Click on the Setup tab and verify that in the drop down box it is set to: Auto Configuration-DHCP.Then verify that the time zone at the bottom is set accordingly. Do not make changes to any other settings on this screen.
2) Click on the Wireless tab at the top. Set the Wireless Network Mode to Mixed
Then choose a Network Name. This is the connection that you will connect your laptop to wirelessly.
Set the Wireless Channel to 11-2.462ghz
At Wireless SSID Broadcast click on Enable
DO NOT EXIT THAT SCREEN
3) Directly above the box where you entered MIXED, click on the sub-tab labeled Wireless Security
Security Mode: WPA2 Personal you can use WEP but WPA2 is more secure. If your laptop has connectivity issues with WPA2, try using WEP.
WPA Algorithms: I use TKIP+AES
WPA Shared Key: This is YOUR network key. Write this down and keep it in a safe place or just remember it. You will need this when you try and connect your laptop wirelessly.
Group Key Renewal: should already be set to a default of 3600
Click on the SAVE SETTINGS button
The last thing I do is I go back through each page and if some changes weren't saved I fill in the appropriate information and click the SAVE SETTINGS button for each page. You shouldn't have to but it doesn't hurt.
Last but not least, go to your laptop ( I would recommend restarting it) and turn on the wireless. You should see your newly created network and after choosing to Connect To A Network, enter your Network Key and you should be good to go.
Hope this helps
Posted on Jul 08, 2009
SOURCE: Can't connect Toshiba laptop to Linksys Wireless Routher!!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. your desktop computer can connect to the internet if u pull up a browser. First we need to access the setup page of the router by typing at the url of the browser:192.168.1.1
2. it will show the setup page of the router. u can set the router on the specific internet setup that u have. since the router us setup already u have the internet connection thru the desktop computer using a wired connection..
3. Look for the wireless settings of the router and create first a ssid or wireless network name then u can as well set the wireless security by selecting wep, wpa, wpa2 then tkip.
4. once your done with the wireless settings, check now the settings for the toshiba laptop computer, some laptop wireless network adapter comes up with a software, I have a dell laptop and I dont use the software for the wireless adapter to connect to wireless, I disable it and use the wireless zero configuration of microsoft windows. u can check the wireless adapter software at the lower right corner of the taskbar, u can disable it by right clicking it and there will be an option to select to disable and sometimes there is an option as well to use the wireless zero config. given u already disable the software and there is no option to use the wireless zero config. u can click on start then run and type services.msc and the services tab will pop up and scroll down to the button of the services and u will see the wireless zero config, just right click on that line and enable it. once its enable it will show a wireless icon on the lower right of the task bar its like a little double computer icon, if it does not show, check on ur laptop maybe the wireless switch is off, the switch is located on the sides of the laptop or on the key area or check on ur manual on how to turn on the wireless switch if u cant locate it. once the icon show, right click it and select on view available wireless network and it will list all available network in range included the wireless network that u created, just select it and connect, then it will ask the password, type the password and connect. u should be connected.. I hope this will help u.. pls feel free to get in touch if u have any concern.
Posted on Aug 23, 2009
Link led keeps on flahing and act led is not coming only
Try resetting the Linksys router.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 02, 2013 | Linksys Wireless-G WAP54G 802.11g/b...
Wireless security
I think you should upgrade the firmware on your router.
After upgrading the firmware reset the router and reconfigure it manually.
I will also suggest you to create a new wireless network and use security modem WPA.
Try to connect to the new wireless network and see if that works.
See linksys router setup
Watch : How to reset Linksys router.
Jan 25, 2012 | Linksys Wireless-G Broadband Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
Jun 17, 2010 | Linksys Wireless-G WRT54G Router
I am unable to set up my Linksys WRT150N router security. I am using a Mac Computer OS X v10.5.8. I can access the internet using the router but only through an unsecure connection. When I go to change the...
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Jan 24, 2010 | Linksys Wireless-N WRT150N Router
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
Router installation
THis can be a problem with the wireless settings of your router, I believe your laptop is trying to connect wirelessly to your router, This can be solve by accessing the router setup page and do some changes on its wireless settings settings like the SSID and the most important one the wireless security..If you're not familiar on how to do that I will advcie you to call LInksys tech support so one of their tech can walk your through with that process, they are open 24/7 this is the number 800-3267114.......
Hope that helps.........
Sep 16, 2008 | Linksys Wireless-N WRT150N Router
Linksys WRT120N Router Logo
133 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
