FixYa.com
Tags:
Microtek CX6 Multimedia Projector
Microtek cx6
posted by Fergicop on Apr 17, 2008
I power up my projector and it works fine for several minutes then the light goes out. Turn it off and back on it does the same thing. What could be the cause?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 18, 2008
Not Rated (0)
Marrie
Rank:Wiz Wiz
Rating: 84%, 255 votes
Hi there
Firstly check when the Projector is switched on , if all the fans are running.
If they are , then it can only be one of two things - either the Powersupply or the Ballast that has gone faulty.
Is there any indicator lights on the unit that flickers , and also what colour ?
Take out the lamp and check for any irreugularities on it like discolouration ( vein like looking marks in either white or black ) or if there is any bubbles on the shaft of the lamp. In which case the lamp will be at fault and will need replacement !
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
movie mate 30 brojecting blue...
Hi; My name is robert and i... Answer This...
HI to all my heros
Please am using a Toshiba... Answer This...
Remote codes
Hi, I'm looking for the IR Hex... Answer This...
toshiba projector
i brought a toshiba projector... Answer This...
Dell 4100mp projector
My projector is about 3-years... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
