Question about Haier HC125FVS Wine Cooler Beverage Cooler
Haier HC125FVS - clicking on and off but doent cool
Problem for Haier HC125FVS Wine Cooler Beverage Cooler:
Is clicking on and off but does not cool or run
  • 1,284 Answers
Hi, sounds like an "overload and relay" on the compressor.
This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common.
It's more likely to be a relay starter problem which is usually located near the compressor, all you need do is change it.
Take care
Posted on Jul 04, 2010
Need beverage cooler to be colder
it probably has a leak & needs freon. in most cases there are no ports to check the freon level. you will have to add them. if you dont know how to do this it will be cheaper for you to go buy a new one vs. paying somone to fix it.
Oct 15, 2013 | Haier HC125FVS Wine Cooler Beverage Cooler
I have a Haier HC125FVS Wine Cooler that has stopped cooling. The compressor hums but will not start. Is the starter #6R8MC a two piece part? I have unpluged the black part with that number, but there is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Haier HC125FVS Wine Cooler Beverage Cooler
I am getting frequent frost build-up on the inside back wall. I have been told by RepairClinic.com to check the DEFROST TIMER. Where is it located? I have already checked behind the light cover and on...
llok in the back by compressor . also if the wirign sch is on unit find the wiring and folow to it .. repair clinic is on the right track and when you find it and replace it problem over .. it 's not hard to find . .. mm
Aug 17, 2010 | Haier HC125FVS Wine Cooler Beverage Cooler
I LOST MY KEYS FOR THE COOLER WHERE CAN I BUY,OR HOW DO I OPEN THE DOOR
you will like this,same thing happened to someone i know and they went into thier local dealer and asked to borrow a key,the dealer said yes but will take a $25 deposit for the return within 48hours.
guess what.....the first key did not fit,but the third one did.....happy ending......i supose they could have taken the cooler to the dealer,but is was full of beer......
Aug 14, 2010 | Haier HC125FVS Wine Cooler Beverage Cooler
The unit is not cooling
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
I was defrosting my fridge and punctured the tube
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
Dec 12, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Sounds like an "overload and relay" on the compressor. This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common. Hope this helps!
Dec 06, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
There is a tiny hole in the inside back and the freon gas leaked, is this repairable?
Hi:
It should be repairable. You would need a Heating/ Air Conditioning repair shop to silver solder the hole closed, and possibly sweat on a valve to evacuate and refill the system. I would call around and ask if the shops do this sort of thing. I had a similar repair done on a window air conditioner, and it saved me money!
Nov 17, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Haier HC125FVS Wine Cooler Beverage Cooler Logo
217 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
