Question about Sony KV-32S42 32" TV
WHAT WOULD CAUSE THE TV BLINK ON AND OFF ? - Sony KV-32S42 32" TV
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
The picture tube is right on the edge of working with the set's AKB, or auto cathode balance. All Sony tube TV's use AKB. AKB is a circuit that attempts to compensate for aging of the picture tube (among other things), and if the tube isn't conducting enough (due to age), it will intermittently blank the screen or, in severe cases, not allow the picture to come on at all. But if you are comfortable taking the back off of the set and making a minor adjustment, you can probably restore the picture for a while longer. Take the back off, turn the set on to a blank channel (receiving snow). You will see a large gizmo with a thick red wire coming out of it going up to the glass on the picture tube. That's the high voltage (a.k.a. flyback) transformer. On this transformer will be a small knob labeled "Screen." If you turn this control ever-so-slightly counterclockwise, the screen will blank off immediately. But if you turn it just a bit clockwise, it may fix your problem. Don't go too far with this control, just enough to make it work. This is DANGEROUS FROM HIGH VOLTAGE, so make sure you have a qualified tech help you do this.
Posted on Jul 04, 2010
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
After watching TV for a few hours it will turn off by itself. Then the light will blink 3 times. If this is the lamp door switch where is that located?
THERE ARE 2 SWITCHES IN THE TV THAT WILL GENERATE 3 BLINK SHUTDOWN ONE FOR THE LAMP DOOR AND ONE FOR THE LAMP ITSELF. I HAVE SEEN GENERIC LAMPS IN THE PAST THAT DON'T FIT QUITE RIGHT AND CAUSE THIS PROBLEM. OTHERWISE MAKE SURE THAT THE LAMP DOOR IS SECURE COMPLETLY.
Dec 16, 2010 | Sony Televison & Video
My 53 Inch Pansonic TV does not switch on. What would be the cause ?
Does the power light blink? If so let me know the number of blinks snd I can help you determine whats wrong.
Jun 02, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Wavie lines color destorted then nothing, set will not power up
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(or input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If it is 2,2 I have start to finish step by step instructions for repairing convergence problems that cause the 2,2 blink code.
if this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 27, 2009 | Mitsubishi WS-55909 55" Rear Projection...
When I turn the TV on, the Lamp and Temp lights blink red. Then the TV shuts down after a minute. Do you know what the cause is?
How long has it been since the lamp has been change? If the lamp went out, this would cause this problem.
Nov 10, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Our tv has a flashing power button. We cannot get it to stop flashing, and we cannot see anything on the screen.
blink--blink---blink or blink blink-----blink blink---blink blink?or blink with the OPC?
Mar 28, 2009 | Sharp LC46SB54U 46 in. LCD TV
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
Dec 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Panasonic 42" Projection TV
It could, but highly unlikely. Does the power light blink series of blink then pause for a second? Let me know it may be going into shutdown and blinking a diagnosis code.
Jan 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony KV-34HS510 blink codes
I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
535 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
