Question about Cell Phones
No audio from cell phone
I'm using a simple LG phone that's usually trouble free. The audio quit on me. It worked fine, the last time I used the phone. Now I can make a call and complete a connection, but I hear nothing from my phone.
This is not the same problem as when the phone is on silent mode. I can change the mode, and I can see clearly that it's set for normal mode. It's just that the phone gives no audio output.
In my case, the problem has been solved, but it may be worth posting here. When I searched the web for clues to my problem, I didn't find anything. Maybe the next person who has this problem can benefit from the same solution.
The cause of this problem was debris in the headset jack. Somehow it caused the phone to believe that a headset plug was inserted. As a result, the phone was trying to transmit audio to a headset instead of to the phone's ear speaker.
  • GtotheJ Apr 29, 2008
    i have the same problem with my k550i except that its does it intermittently. its really starting to irritate me. removed batterty and restarted and problem still happens. checked for debris in the battery charger/headset jack and nothing there. should i open up my phone?
SOURCE: LG VX5400 Cannot hear during calls
I was able to get the phone "unstuck" from this mode by plugging and unplugging my wired headset several times. Perhpas the contacts were dirty inside the jack...
Posted on Sep 21, 2009
Testimonial: "Thanks!"
VOTIT
  • 2071 Answers
SOURCE: Phone problem
You must reset your cellphone,remember when you going to execute reset all your saved data will gone, you better to saved it.Go to setting then select factory default setting....
Hope this may help;
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
SOURCE: silent mode activated is on and won't come off.I can not hear my music or ringtones on it.
you can change this by going to settings>profiles> general>activate. this is a general solution and i am saying this since you havent specified the manfacturer and model of the phone. you can also refer the instruction manual to change it.
Posted on May 31, 2009
SOURCE: trouble with ear jack and speaker, lg voyager VX10000
Agreed, the problem does seem to be these pins, I would guess it's something to do with the charger moving them when placed and removed. Which would explain the issue if you've never used a headset. I bought a headset trying to fix this issue, I tried plugging and unpligging it with no result, I did hear sound through the headset, though it didn't fix it when I unplugged it. I was able to fix it by taking a fine sewing needle and carefully move these pins on the side, but if you do this proceed with caution as they are fragile. Hopefully this page helps, because I know the frusteration of trying to figure it out and fix it.
Posted on Jan 26, 2010
Bajanguru
  • 7752 Answers
SOURCE: Bluetooth not working anymore
CYBERSOUL - take the phone to a mobile center and ahve them correct it for you.
Posted on Jun 29, 2008
How can i install mobile dictionary on my lg gm200 cellphone?
Its very simple, you open any web site, which are providing downloads of jar programs,either directly to your mobile or to your PC. Then transfer the jar file to your mobile if downloaded to PC and run it.Thats all, Dictionary is now ready to use.This way i loaded in my cell last week and now it works like anything. Try and enjoy.
Jun 18, 2012 | LG GM200 Cell Phone
Phone quit. will not charge or turn on. worked fine last night.
Try pulling the battery for about 60 seconds, and clean the contacts and make sure that the battery sits properly and has good contact with the phone.
The LG Ally is designed to turn on while it is charging, so try attaching it directly to a wall socket and possibly using another charging cord if you can. If a new cord plugged into the wall does not turn the phone on, the phone probably has a severe hardware issue that you may not be able to correct through repair, I would recommend sending it in for warranty repair if you are still under warranty unless the phone has physical or water damage.
Mar 06, 2011 | LG Ally Cell Phone
How to unlock a lg cosmo code phones
HI che146283 to unlock your cosmo you need to put in the last for numbers of your phone number.if this doesn't work i need you to dail *22899 this reset the lock cosde to the last four numbers of your phone number. This should fix that problem for you.
Dec 03, 2010 | Cell Phones
My phone is asking for the puk code its a lg kp170
Hello i hope u 'll be fine.... thanks for using fixya.
As soon as you type three times wrong security codes, the phone gets blocked and ask u for the PUK.
  • Simple solution is go to your service provider to unlock that code, They 'll unblock the PUK free, Then u 'll be able to access your phone without the security code
Best of luck
Kindly do rate if it is helpful,
THANKS & Keep using Fixya
Feb 23, 2010 | Cell Phones
LG Model UX8360 cell phones batteries drain to quickly
the batterys are defective maybe or the devices , go into verizon they are usually very helpfull and will replace them
Oct 02, 2009 | LG Lotus Cell Phone
I accidentally locked my env and i dont know how to unlock it
LG's make it the last four digits of your cell phone number. so its the last four digits of your cell phone number.
Aug 04, 2009 | LG enV VX9900 Cellular Phone
Trouble with MMS, texting and internet work fine, but cannot use mms.
get the mms service activated and get the settings for mms from ur service provider
Jul 21, 2009 | LG Incite Cell Phone
Bluetooth issues
The solution was quite simple. Always give your new hands free kits the full charge before trying to use it. I never thought it would make that much of a difference but it obviously does. I feel terrible about all the hands free kits i have taken back as faulty.
Feb 18, 2008 | LG Shine KE970 Cellular Phone
LG PRADA Mic Problem
simple solution. get a new microphone.
Feb 06, 2008 | LG Prada KE850 Cellular Phone
Cell Phones Logo
1,714 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
