Question about Maytag MSD2650HES Stainless Steel Side by Side Refrigerator
Water line is slow - Maytag MSD2650HES Stainless Steel Side by Side Refrigerator
  • samuel_golds Jul 04, 2010
    please read all my comments and advise
  • 2,272 Answers
One thing to check is the connection to the plumbing in the wall. Sometimes the connections have shut-off valves that can be opened or closed (sometimes just partially). If the shut off valve is partially closed it can restrict the water's flow to the dispenser for both the liquid water and ice. Another possibility to be checked is water filter.If its very old or got clogged by dust particles then it has to be first cleaned and checked.If same problem then it has to be replaced. To locate the valve:--
you will need to pull your fridge out enough to get behind it.. follow the water supply line to where it connects to the fridge. you'll need to remove the cover on the back of the fridge and your water supply line will connect directly to the water valve
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 04, 2010
    President:
  • 1,561 Answers
Start by checking the water supply going to the fridge using the technique of the Master:
  • Turn off the water at the saddle tap valve
  • Disconnect the water line in the back of the fridge. Place the disconnected end in a bucket and open the saddle tap valve.
  • Observe the flow rate–water should shoot out vigorously. If not, then the saddle tap valve is probably gunked up with sediment and you’ll need to replace it.
That should restore normal water pressure.
If the water supply flow rate test, described above, appears normal, then the water inlet valve on the refrigerator may be gunked up with sediment. Here’s how we check for that:
  • Reconnect the water supply line to the valve and turn the water back on.
  • Disconnect the nylon tube from the dispenser side of the valve and replace it with section of tubing so you can out the other end in a bucket.
  • Now actuate the water dispenser and observe the flow out of the tube. It should be the same as the flow you observed in the first flow test described above. If not, then you know the valve is restricting the flow replace the valve.
Take care.
    can u email me a picture of where is where?
    i see the water line side and i have already checked that, but the other set of tubing i dont see how to remove it looks like its just a pinched little plastic plug or not sure, its light blue in color and i dot see how to remove it? is that what you are referring to ?
    pressure dispenser in the door went to a 10th the original
    pressure, i assumed it
    was the filter bc it had been a year no change. replaced my valve on the
    back of the
    fridge, still no go.
    he checked the line for air and to
    make sure the water line was working, all along the ice cubes were a
    flowing
    the whole time no issues. now i have
    just lived with slow water pressure. my father in law took
    out the ice bucket to fill a coler and ever since the ice maker has
    stopped
    working, i saw a small amount of ice formed in the maker that had not
    been
    released so i uplugged it and defrosted it then reinstalled but still no
    ice
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
Feb 07, 2015 | Maytag Washing Machines
Can the water flow be made faster?
A SLOW WATER FLOW IS USUALLY THE RESULT OF A CLOGGED OR INHIBITED WATER VALVE LINE OR HOSE. IF THE LINE IS FROZEN OR HAS DEBRIS IT WILL SLOW THE FLOW
May 13, 2014 | Samsung RS2630WW Side by Side Refrigerator
Water run slow
Did you install the water line? There is likely a blockage in the line itself or at the valve. Is the valve in the line feeding the refrigerator completely on?
It may be that a piece of packing, dirt or other debris from install is in the line itself.
Apr 29, 2012 | GE Refrigerators
Change water filter. now water is running slow. put old filter back in, still running slow. ICE2O
Hello, Thank You for using FixYa. I will be helping you today.The only thing that can cause slow water is low water pressure from the house line a bad filter or a frozen water line or tank. Most of the time its the house water supply it should be at least 35psi.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
My superba is leaking water from the white block where the water feed line goes into the ice maker how can this be fixed ??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak
The valve can leak because of sediment in the water preventing it from closing or low water pressure
. Disconnect the ice maker line from the water inlet valve valve(on the back where the water supply connects). and watch to see if it has a slow drip.
Nov 19, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water dispenser is slow
Change out the filter. If it still happens then you have a blockage in the line. Disconnect the line and flush out.
Jul 26, 2009 | GE Profile TPX24PBDCC Side by Side...
Why would the water start coming out very slow?
If you are referring to water coming out the fountain it could be a leak in the system somewhere allowing air into the lines that run the water, if you are referring to water coming out of the ice maker itself you need a new ice maker the lining is bad
Jul 14, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water from dispenser slows down while filling cup
If your water is slowing down the screen on the water valve may be stopped up or the filter (if it has one, when was it last changed?) or line feeding the refrigerator may be stopped up or the water valve its self may not be opening all the way and staying open.
To eliminate 3 of the external problems take the water line off the fridge and run some water into a pan and open and close water like at your kitchen sink and see if the water slows or speeds up noticeably while running into the pan. If so the problem is in the water line. While you have thew line off remove and inspect the water inlet valve screen and replace the hose washer (if so equipped) this brings your problem if you have not found it yet to the inside of the fridge. Usually on the corner of the door hinge the water line makes a turn up to the dispenser inspect it there and see if its twisted or kinked. Also there is a water resiviour inside the fridge look there for the same thing and possibley where food may have been forced agianst the line.
If you still dont find it by now I'D have to know what you did find and where.
If this helps you please rate me with as high a rating as you can and thank you for using fix ya.
Apr 20, 2009 | Amana AFI2538A Bottom Freezer French Door...
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Water in refrigerator door coming out slow
Hi Ben22 Sounds like some thing pluging the water line or the water line pinched some where.. if the hole was 1/4 inch you should get enough water with that big of a hole. I would check the water line for a obstruction. Let me know if this helps. Krazytech
Sep 29, 2007 | Whirlpool ED5SHAXM Side by Side...
Maytag MSD2650HES Stainless Steel Side by Side Refrigerator Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
