Question about Toshiba Satellite L505-S5966 Notebook
Key board and mouse pad not working - Toshiba Satellite L505-S5966 Notebook
    Genius:
  • 1,456 Answers
Hello
To fix your problem please do the following;
Look for Fn function key on your keyboard- Most laptops have this special key next to the Ctrl key on the keyboard. It is easy to find
Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touchpad, which is to control the touchpad of your laptop.These function keys also control the brightness, sound, wireless etc.
Now hold down the Fn key and the key that looks like the mousepad to enable the touchpad, in Toshiba laptops. You press them again to disable it
If none of the above works, plug in an USB mouse, then check into the Control Panel -> touchpad or mouse and keyboard configurations. Also, check Device Manager if the touchpad driver is installed and working properly.
For the keyboard;
Diagnose the problem. When you press a key on your laptop keyboard, does it get stuck? Does the computer respond to your inputs? In almost all of these cases, the solution will lie in opening up your notebook's keyboard. However, to prevent extra work, press every key (do this in a word-processing program) and see which keys are affected. If every single key on a keyboard does not respond, you might have a software issue, which may require specialized help.
Clean the area around the keys that are not working. A damp lint-free cloth should be used to clean the surface of the affected keys. If you have stuck keys, use a Q-tip to clean under them, but take care not to pry the keys up, as this could result in further damage to your keyboard.
Remove the keys that are not working. Do this by grabbing some fingernail clippers and pulling out the hook-like fingernail cleaner extension. Use the small hook to gently pull the key up , which will expose a collapsible plastic hinge (commonly known as a key retainer) as well as a small rubber circular piece. Gently lift both of these pieces out of the keyboard.
Wipe the keyboard sensors clean with a dry cloth. The sensors are the little silver foil-like strips you see after your key components have been removed. Be very careful wiping these down--if they are damaged, they are very expensive to replace. Just gently dab it with a dry lint-free cloth to remove any dust/crumbs/particles that are interfering with your keyboard's functionality. Do not moisten the cloth with water or cleaning solution, as this heightens the risk for damage.
Reassemble and replace the keys. Simply fit the key retainer as well the little rubber piece together in the way you found them and then firmly press the key cap back in place.
Test your keyboard. Open a word-processing program and then press the replaced keys. If they still don't work, try restarting your computer, or activating a system restore point (to ensure that the problem is not software-related). If the keyboard is still not working, then you may want to think about taking the computer to a repair shop or replacing it altogether. (Keyboard repairs are very expensive.)
Posted on Jul 04, 2010
5 Suggested Answers
mellomania
  • 121 Answers
SOURCE: keyboard and mouse inoperative
download their drivers from the net ..search them by model number of ur pc
Posted on Nov 15, 2007
  • 55 Answers
the best thing you can do is hook a wireless keyboard and mouse to your laptop. That's what i did and all is working well
Posted on Dec 16, 2007
cpenzes
  • 1102 Answers
SOURCE: Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Posted on Feb 02, 2009
sanguine
  • 369 Answers
SOURCE: touch pad quit working recently.
Please visit Asus website and download the touch pad driver and manual for your computer mode.
http://www.asus.com/entryflash.htm
Posted on Jun 03, 2010
Why does my vaio keyboard and pad stop working
Connect External USB keyboard and Mouse and use for a while.
If all keep working problem is likely with connectors or Motherboard
Jan 30, 2014 | Sony Vaio VGN-NW125J Laptop 2.1GHz Intel...
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
Touch pad quit working recently.
Jun 03, 2010 | ASUS Eee PC 1000H Laptop
My mouse pad isnt working but a USB mouse is, tried to use Fn+F7 but didnt work. Any help?
Is there a function key on the laptop? (Fn usually blue ink) is there a key with the symbol that looks like mouse pad. Hold down Fn then the mouse pad key and that should enable the mouse pad.
As you have suggested the F7 key is the one for the mouse pad, and hasn't made any difference, have you somehow corrupted the drivers. You can download them from the acer website.
when did it last work, you cloud try a system restore. Remember to press Fn + F7 again and give it a moment to enable( just in case the last time you tried it, you turned the hardware off despite it's lack of functionality)
Dec 29, 2009 | Acer Aspire 3000 Notebook
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Jun 13, 2009 | Acer Aspire 5610-4648 Notebook
Keyboard and mouse pad dead. all else seems ok. got dropped
If it works with an external keyboard and mouse then you need to replace the palmrest.
May 13, 2009 | Computers & Internet
Wireless keyboard stopped working; mouse still does though
on this key boards problem is that they key pad circuit board has no mechanical connection or wire connection it merely lays across the circuit board loosing contact that's why if you squeeze the bach it starts working again
May 03, 2009 | Gear Head WIRELESS keyboard/Mouse
Keyboard and mouse inoperative
Dec 14, 2007 | Computers & Internet
its the battery. disconnect the battery, plusg it up and start you computer. the mouse and keyboard should work fine.
Nov 14, 2007 | Computers & Internet
Toshiba Satellite L505-S5966 Notebook Logo
1,100 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
