Question about Samsung LN-T4665F 46 in. LCD Television
It taske up to 15 minutes for the television to
It tasks up to 15 minutes for the television to start, once the power button is pushed we hear clicking sounds until if finally starts
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
1. Lay the TV Face down on a padded Table and removed all the screws. The tback just Pops off.
2. There is a protective cover over the circuit board. unscrew and pull off.
3. Unhook all of the wire attachments that connect the board to the rest of the TV and unscrew the 6 screws that hold the board down and pull it out.
4. There may be bulging capacitors on the top right or somewhere on the board. You can take the whole board into a repair shop and they can tell you what replacements to buy. (Upgrad to 35v to prevent future problems)
5. De-solder the backs of the bulging capacitors and clipd the leads.
6. Put the new capacitors in their place (watch for the polarity. bend the leads to the side to hold them tight and solder them down.
7. Replace the board.
****WORKING INSIDE A TV IS DANGEROUS DUE TO HIGH VOLTAGE***IF UNSURE, LEAVE IT TO A PROFESSIONAL.
Best Regards,
Beach TV Repair
Posted on Jul 04, 2010
Lost start button and icons
Are you saying there are no icons on yourdesktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press andHold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click theImage Name column to get them in alphabetical order. Look forexplore.exe, if you see it listed click it once to highlight it then click theEnd Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the leftand select the option New Task (Run). When the Create New Task window openstype: explorer.exe and press OK. Your items will start populating andappearing on the desktop.
Mar 29, 2012 | Computers & Internet
After bootup only Ease of Access and Shut Down buttons visible
Buttons where? Are you saying there are no icons on your desktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press and Hold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click the Image Name column to get them in alphabetical order. Look for explore.exe, if you see it listed click it once to highlight it then click the End Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the left and select the option New Task (Run). When the Create New Task window opens type: explorer.exe and press OK. Your items will start populating and appearing on the desktop.
You need to run a virus scan because something might have caused this to happen.
Mar 26, 2012 | Acer Aspire One PC Notebook
I started Adobe Air and now cannot get out of the application. There was no documentation accompanying the application. I cannot find the Exit buttons
Open task manager by pressing Ctrl+Alt+Delete buttons on the keyboard at the same time, or by clicking Start -> run -> taskmgr and press enter. Once task manager is open, click 'Applications', select Adobe Air and click End Task.
Jul 17, 2011 | Computers & Internet
Adobe Acrobat has taken over my system, & i cant open anything..how do i fix this problem...much thanks
Hi, cfreeman90
Note that this answer assumes you are using a PC. Try using the task manager to close Acrobat. To do so, hold down the Ctrl and Alt keys and then push the Delete key. The task manager window should open and Adobe Acrobat should be on the list of running programs. Click on it and then click on the "end task" button below the text box witht the list of programs. If Acrobat still won't stop, give it a few minutes, then click on the process tab which will switch to a list of running processes, and end any process with Adobe or Acrobat in the title. This may cause your computer to restart, though. Once its off, I would recomend that you uninstal the program.
If you don't already know how to uninstal a program, here it is. click on start and click on "control panel" on the start menu. When the control panel window opens, click on "add and remove programs". This will open a new window with a list of programs installed on your computer. On the list, click on adobe acrobat. There should be a button marked remove. Click it and click on yes when the next widow to open asks if you want to remove the program.
Jan 17, 2011 | Lanier UNKNOWN
I have a second hand packered bell laptop, how can i check the batery power?
for xp go to start, settings, control panel, power options, power meter will display it. start, settings, control panel, power options, advanced, then checking display on task bar and applying will put it on task bar.
Aug 10, 2010 | Packard Bell FT500 15" LCD Monitor
I tried last night to restart my laptop and it is stuck with the circle and the words "logging off". I unplugged the power over 15 hours ago. what do I do
push control button, alt button, and delete button at the same time, task manager will come up, click end task......this should help......
Nov 10, 2009 | Dell Inspiron 1526 Laptop
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Samsung LN-T4665F 46 in. LCD Television Logo
1,020 people viewed this question
Henry  Thomas
Henry Thomas
